Badiceman Posted January 28, 2008 Share Posted January 28, 2008 Im driving down from skiing in the snow in 4h and the road clears up. I pop it into 2h but the hubs are still locked? Do I need to stop and backup the three feet to unlock the hubs? Link to comment Share on other sites More sharing options...
Casey.T Posted January 28, 2008 Share Posted January 28, 2008 yes.... Link to comment Share on other sites More sharing options...
adamzan Posted January 28, 2008 Share Posted January 28, 2008 (edited) But i don't think it hurts to do it at a later time other than more drag so worse gas mileage. Edited January 28, 2008 by redfinder Link to comment Share on other sites More sharing options...
Badiceman Posted January 28, 2008 Author Share Posted January 28, 2008 Thats pretty much what im asking. Is there anything wrong with driving with the hubs locked on dry pavement? Link to comment Share on other sites More sharing options...
88pathoffroad Posted January 28, 2008 Share Posted January 28, 2008 It'll drag down your gas mileage and spinning the front diff at 65-75 MPH probably isn't the best idea... Link to comment Share on other sites More sharing options...
Simon Posted January 28, 2008 Share Posted January 28, 2008 (edited) Spinning the front diff at 65-75MPH will hurt nothing. I've run my warn manual hubs in the locked position countless times, in semi-bad weather, in 2wd, as a precautionary measure. Remember, the R50 came stock with a fully engaged front driveline, and it has the same differential as the WD21. If your 4wd light is still on, it means that your T-case has not disengaged, probably due to the front driveline still spinning. Sometimes it will pop out on it's own, sometimes reversing is necessary. If that's the case, you DO have to reverse to get it to disengage, as running in 4wd on dry pavement will harm the truck. Edited January 28, 2008 by Simon Link to comment Share on other sites More sharing options...
adamzan Posted January 28, 2008 Share Posted January 28, 2008 My light won't go off unless I reverse. Yet when i take it out of 4wd and don't back up it only drives the rear wheels still. Its nice to know now that i can leave the hubs engaged in the bad weather. Link to comment Share on other sites More sharing options...
