kidrock Posted January 18, 2008 Share Posted January 18, 2008 Hey guys, I'm trying to replace my antenna. OK, all the instructions I have read says; just take the base nut off. Turn the key on, and pull the mast and the cable out. For some reason mine will not come out. It's like something is holding it that I can't see. Any ideas? Thanks. Link to comment Share on other sites More sharing options...
XPLORx4 Posted January 19, 2008 Share Posted January 19, 2008 Hey guys, I'm trying to replace my antenna. OK, all the instructions I have read says; just take the base nut off. Turn the key on, and pull the mast and the cable out. For some reason mine will not come out. It's like something is holding it that I can't see. Any ideas? Thanks. You turned the radio on, too ,right? Link to comment Share on other sites More sharing options...
k9sar Posted January 19, 2008 Share Posted January 19, 2008 yea, remove the nut and make sure everythings loose, turn on the radio and grab the antenna mast and as it comes up, continue to pull. You will have to pull about 6" of the toothed nylon out of the gear when you get to fulle xtension. Putting one back is just the reverse. Turn on the radio, feed the nylon into the home (the right way) and push down gently as you have someone turn the radio off. It should grab and pull in. Alternately (at least on the WD21's), you can get at the assembly by taking off the fender off. Link to comment Share on other sites More sharing options...
revgolem Posted January 19, 2008 Share Posted January 19, 2008 ive had to replace quite a few of these on various vehicles and theres a really good chance that you are going to have to remove and open up the entire assembly to untangle gnarled mess of nylon. usually not too difficult, just watch for any rogue springs or gears to fall out when you take it apart. Link to comment Share on other sites More sharing options...
kidrock Posted January 19, 2008 Author Share Posted January 19, 2008 (edited) ive had to replace quite a few of these on various vehicles and theres a really good chance that you are going to have to remove and open up the entire assembly to untangle gnarled mess of nylon. usually not too difficult, just watch for any rogue springs or gears to fall out when you take it apart. Thanks. It's got be be something like that because I have followed all the steps listed above. I just hate to take all that s#*h apart. I've found out if it says "simple" or "easy" look out. Edited January 19, 2008 by kidrock Link to comment Share on other sites More sharing options...
CALPATHY Posted January 20, 2008 Share Posted January 20, 2008 Thanks. It's got be be something like that because I have followed all the steps listed above. I just hate to take all that s#*h apart. I've found out if it says "simple" or "easy" look out. Yup, it was so easy that I replaced the whole asembly to make it harder on myself. Link to comment Share on other sites More sharing options...
