Baaaaaad Gas Mileage
ardavis78
I've got a '96 Pathy w/ approx. 125,000 miles on it. My gas mileage never was that great, but I am recently getting about 10 -11 mpg. I just replaced my plugs and air filter(K&N). I thought that would make a big difference because the gap was approx. .080 on the old plugs(new are gapped @ .040) ,but nothing. I know about the oxygenated gas in the winter, but this is awful. My check engine light isn't on and the truck runs very well. Any hints maybe? I even installed manual hubs too. Any little tips or tricks would be appreciated. Thanks!!
A bad O2 sensor will sometimes not set a CEL.
Another possiblity is that the coolant temp sensor for the EFI has died. This won't set a CEL either.
Agreed! In my 98 I replaced the coolant temp sensor at about 90K and got 2 mpgs back....I was really excited about this maint. because it was sooo easy and about $24. I would look here first. If you have the loot replace all 4 O2 sensors and never think about it again, or for at least 85-100K.
I'm kind of in the same boat.
But I did: plugs, wires, fuel/air filter, all 4 O2 sensors, PCV valve, and seafoam, and still get ~230 to a tank which equals ~12MPG but with the 31s I am running I don't know what the actual mileage is. I'm guessing ~13MPG. I guess the next things I can try is cleaning the MAF sensor and replacing the coolant sensor. Where is it located? I'm guessing on the lower part of the radiator?
The 2 prong coolant sensor I changed was on the thermostat housing. 19mm wrench is all you need. Cost bout 20 bucks.
  • 3 weeks later...
My gas mileage has also gotten really bad lately. My check engine light goes on and off so I wasnt sure what the deal is. A lady I work with has a 99.5 and she is having the same issues. Her husband is a mechanic and he thinks its the 02 sensor. I was gonna hold off doing anything until spring, but Ill be broke by then the way its going. I figured the sensor would be super expensive because they are on my M3, well I guess everything is expensive on it, but you guys are making it sound pretty cheap.
So what else should I get? Coolant sensor? I was going to change my spark plugs until I saw all the stuff I have to remove to get to them. Is replacing them as big a PITA as it looks? Any DIYs?
Also, can I get these parts from an auto parts store like auto zone or do I need to go to the dealer?
Thanks in advance.
Replace:
O2 sensors with good ones (Denso)
Plugs & wires (use the supplied kit under the rear seat makes it very easy, even #6)
PCV valve
Air filter
Fuel filter
Coolant temp sensor
Clean the MAF sensor
Seafoam the the intake, fuel, crankcase
I bought my O2 sensors & PCV valve online because they were a lot cheaper than in the store. www.autopartswarehouse.com
Hi!!
could you answer this questions?
1. what is MAF?
2. Where do i find MAF?
3. How can i clean MAF?
Thank you very much!!!!
1 - Mass Airflow Sensor
2 - it's a plastic box that is connected to your air cleaner box.
3 - Should be an article about it on here. Just need some electrical contact cleaner and some q-tips.
