texasbudman Posted October 24, 2007 Share Posted October 24, 2007 Good Day, I've had gremlins in my Pathy lately and have just been introduced to the codes (thanks again)... however after reviewing the list I noticed that some are duplicate... any special reason why???? I honestly didn't even know the lil box was for, but I'm a learnin!! Anyhow I won't get the chnace to ck it out till Sat, but if anyone has a heads up please let me know... any useful informaiton is much appricated... Thanks Link to comment Share on other sites More sharing options...
94extreme Posted October 24, 2007 Share Posted October 24, 2007 duplicate? Link to comment Share on other sites More sharing options...
texasbudman Posted October 24, 2007 Author Share Posted October 24, 2007 duplicate? Yhea... duplicate... for example #'s 34 & 37, 72 & 73, 91 & 101... and why are there missing #'s too??? 1986.5-1995 Nissan ECU Flash Codes(all engines) 11 Crank Angle Sensor/Camshaft Position Sensor. 12 Air Flow Meter/Mass Air Flow Sensor. 13 Engine Coolant Temperature Sensor. 14 Vehicle Speed Sensor. 21 Ignition Signal. 22 Fuel Pump. 23 Idle Switch. 24 Throttle Valve Switch. 25 Idle Speed Control Valve. 28 Cooling Fan Circuit. 31 ECM. 32 EGR Function. 33 Heated Oxygen Sensor. 34 Knock Sensor. 35 Exhaust Gas Temperature Sensor. 36 EGR Control-Back Pressure Transducer. 37 Knock Sensor. 38 Right hand bank Closed Loop (B2). 41 Intake Air Temperature Sensor. 42 Fuel Temperature Sensor. 43 Throttle Position Sensor. 44 ECCS Normal Operation. 45 Injector Leak. 47 Crankshaft Position Sensor. 51 Injector Circuit. 53 Oxygen Sensor. 54 A/T Control. 55 No Malfunction. 63 No. 6 Cylinder Misfire. 64 No. 5 Cylinder Misfire. 65 No. 4 Cylinder Misfire. 66 No. 3 Cylinder Misfire. 67 No. 2 Cylinder Misfire. 68 No. 1 Cylinder Misfire. 71 Random Misfire. 72 TWC Function right hand bank. 73 TWC Function right hand bank. 76 Fuel Injection System Function right hand bank. 77 Rear Heated Oxygen Sensor Circuit. 82 Crankshaft Position Sensor. 84 A/T Diagnosis Communication Line. 85 VTC Solenoid Valve Circuit. 86 Fuel Injection System Function right hand bank. 87 Canister Control Solenoid Valve Circuit. 91 Front Heated Oxygen Sensor Heater Circuit right hand bank. 94 TCC Solenoid Valve. 95 Crankshaft Position Sensor. 98 Engine Coolant Temperature Sensor. 101 Front Heated Oxygen Sensor Heater Circuit right hand bank. 103 Park/Neutral Position Switch Circuit. 105 EGR and EGR Canister Control Solenoid Valve Circuit. 108 Canister Purge Control Valve Circuit Link to comment Share on other sites More sharing options...
88pathoffroad Posted October 26, 2007 Share Posted October 26, 2007 I believe duplicate codes are for partial failures or total failures. Missing numbers may simply have not been used by Nissan, who knows? Link to comment Share on other sites More sharing options...
unccpathfinder Posted October 26, 2007 Share Posted October 26, 2007 i would think missing coedes were probably in the prototype ECMs and they decided to not need them and got rid of them for one reason or another...I know when I was at freightliner they did things like that...the other would be that they started with lines 1 5 10 15 and added codes as they went (you generally do this in CNC coding in case you need to add something and it makes it easier) Link to comment Share on other sites More sharing options...
texasbudman Posted October 26, 2007 Author Share Posted October 26, 2007 Okay guys... sounds good to me... you could have made the whole thing up... I wouldn't have a clue... but it make me feel better... So Thanks... But lets assume that one is partial failure and the other is total failure... is it also safe to assume that the first would be partial and the second total???? Thanks agian... Link to comment Share on other sites More sharing options...
94extreme Posted October 26, 2007 Share Posted October 26, 2007 here is another list (from Nissan) no duplicates 11 Crank Angle Sensor 12 Mass Air Flow Sensor 13 ECT Sensor 14 Vehicle Speed Sensor 16 TCS Signal 21 Ignition Signal Circuit 25 Idle Air Control Valve 22 Fuel Pump Control 31 ECM 32 EGR Function 33 Heated Oxygen Sensor 34 Knock Sensor 35 EGR Temperature Sensor (RH) 41 Intake Air Temperature Sensor 42 Fuel Pump Sensor 43 Throttle Position Sensor 45 Injector Leak 46 Secondary Throttle Sensor 51 Injector Analysis 53 EGR Temperature Sensor (LH) 54 Signal Circuit From A/T Control Unit To ECM 65-71 Single Cylinder Or Multiple Cylinder Misfire 72 Three Way catalyst Function 76 Fuel Injection System Function 77 Rear Heated Oxygen Sensor 82 Crankshaft Position Sensor 84 A/T Diagnosis Communication Line 91 Front Heated Oxygen Sensor Heater 103 Park/Neutral Position Switch 105 EGR & Canister Control Solenoid Link to comment Share on other sites More sharing options...
