AlMac Posted September 28, 2007 Share Posted September 28, 2007 hey guys, went to change signal light bulbs today, but couldn't get the bulbs outta the housing... they look siezed in there. tried wd40, but no luck. Im afraid ill brak em if i force em too hard. suggestions? laterez Link to comment Share on other sites More sharing options...
Simon Posted September 28, 2007 Share Posted September 28, 2007 Did you get the ring loosened off? IF so, it's just a rubber o-ring holding them in their sockets. Just pull. If it's the ring you can't loosen off, you can turn them pretty hard without breaking them. Link to comment Share on other sites More sharing options...
unccpathfinder Posted September 28, 2007 Share Posted September 28, 2007 are you pushing in on the bulb and twisting?...if you break one make sure its not your hand against the bulb and then if it breaks use needle nose pliers Link to comment Share on other sites More sharing options...
AlMac Posted September 29, 2007 Author Share Posted September 29, 2007 hey guys, actually i found that i had to remove the amber lens from front of the housing to get to the bulb. the bulb is not removeable from the rear of the housing. I could not see a gasket inside the housing at all or a ring. It looks like the socket has rust on it. i tried the push twist method, but the bulb didnt move at all in any direction, including the movement of pushing it inward! Wow, never been so embarassed to change a silly turn signal bulb. Link to comment Share on other sites More sharing options...
unccpathfinder Posted October 1, 2007 Share Posted October 1, 2007 I've had mine get rusted in on my 95 and my 87 but with enough twisting they came loose...1 time the bulb broke loose from the base but no biggie...I guess I could have mentioned that you remove it from the front but I didn't really think about that... when you finally get it out and replaced I would put some of that dielectric grease on it to keep it from rusting/corroding b/c a lot of times I would have to pull my bulb and clean the contacts and it would continue to work... Link to comment Share on other sites More sharing options...
MikeV Posted October 1, 2007 Share Posted October 1, 2007 a gallon of blinker fluid & your on your way... Had a few rust in the front bumper Link to comment Share on other sites More sharing options...
88pathoffroad Posted October 2, 2007 Share Posted October 2, 2007 Pop the bulb and extract the base with pliers gently? They come out eventually. Link to comment Share on other sites More sharing options...
