wild91 Posted September 24, 2007 Share Posted September 24, 2007 hey i was told to use 5w/20 oil and the ph3682 filter. i know u can use the pg3600(larger filter) i was wondering what is the advantage of having a higher capacity oil filter? other than it has more filter surface area to filter with. and what oil do you use/how much do you use? Link to comment Share on other sites More sharing options...
yozsi Posted September 24, 2007 Share Posted September 24, 2007 wtf? 5w20?hahah. i use 10w30 in the winter and 10w40 in the summer. i also use a micro brand filter. takes about a gallon of oil when you change the oil. Link to comment Share on other sites More sharing options...
BLouisGod Posted September 24, 2007 Share Posted September 24, 2007 that oil is way to thin. I run 10w-40 here in florida due to high temps year round. Link to comment Share on other sites More sharing options...
wild91 Posted September 24, 2007 Author Share Posted September 24, 2007 thanks guys for the info...ill go thicker. I live in central California so its warm but gets into the hi 30s in the winter...but still wondering if their is any advantage in the larger filter Also i noticed a squeak from the front drive system i was wondering if their is any ongoing problems with idler pulleys or anything else. just replaced the fan clutch not too long ago( tho i should have went electric o well i didn't have to pay for it) Link to comment Share on other sites More sharing options...
wheel366 Posted September 24, 2007 Share Posted September 24, 2007 Actually, I was told buy this mechanic in my area who is supposed to be one of the top in the country that I should use 5W-20. I haven't used it but he said it is a better oil. Link to comment Share on other sites More sharing options...
94extreme Posted September 24, 2007 Share Posted September 24, 2007 5w20 is too thin and too thick. nissan says to use 10w30 unless you live in the extremes (temp wise) idler pulley is a known culprit of squeecking up front. they tend to go out once i a while. Link to comment Share on other sites More sharing options...
Simon Posted September 24, 2007 Share Posted September 24, 2007 Weird, both mine and Pezzy's owner's manuals state 5w30 for all temps. We've just changed hers over to 10w30 as she's got a small leak in the rear main, and I'm running 5w30 synthetic. Link to comment Share on other sites More sharing options...
94extreme Posted September 24, 2007 Share Posted September 24, 2007 Weird, both mine and Pezzy's owner's manuals state 5w30 for all temps. We've just changed hers over to 10w30 as she's got a small leak in the rear main, and I'm running 5w30 synthetic. maybe it's a canadian thing.. hmm.. my 94 says 10w30 on the cap and in the manual. Link to comment Share on other sites More sharing options...
wild91 Posted September 24, 2007 Author Share Posted September 24, 2007 idk mine has run on 5w20 for at least 200k of its 250k life with no problems my step dad who had the car before me also is a mechanic Link to comment Share on other sites More sharing options...
wheel366 Posted September 25, 2007 Share Posted September 25, 2007 (edited) Well sometimes the engineers are wrong. As strange as that sounds. My father has a 1984 Volvo 240 series Diesel that states in the book that you should use 15W-40 conventional oil. I read a big article on that car with the diesel engine that said the engines did not last long if you used what Volvo recommended but lasts hundreds of thousands of miles if you used a 5W-30 synthetic oil, which is what my dad uses. Actually he uses the 5W-30 diesel formula from Amsoil. On Amsoil's website and on mobil's website, they also recommend a 5W-30 and not a 15W-40. I'm not saying that engineers don't know what they are talking about but in this case, it was clear that they were wrong by specifying 15W-40 for that car. My dad has around 140k on the Volvo and the engine runs fine. The suspension on the other hand.... Now, in my case I use 5W-30 since the book does say to use it. I may try the 5W-20 but I am more interesting in trying motorsilk first. http://209.200.118.63/index.cfm Edited September 25, 2007 by wheel366 Link to comment Share on other sites More sharing options...
pbdm4k Posted September 25, 2007 Share Posted September 25, 2007 Well sometimes the engineers are wrong. As strange as that sounds. My father has a 1984 Volvo 240 series Diesel that states in the book that you should use 15W-40 conventional oil. I read a big article on that car with the diesel engine that said the engines did not last long if you used what Volvo recommended but lasts hundreds of thousands of miles if you used a 5W-30 synthetic oil, which is what my dad uses. Actually he uses the 5W-30 diesel formula from Amsoil. On Amsoil's website and on mobil's website, they also recommend a 5W-30 and not a 15W-40. I'm not saying that engineers don't know what they are talking about but in this case, it was clear that they were wrong by specifying 15W-40 for that car. My dad has around 140k on the Volvo and the engine runs fine. The suspension on the other hand.... Now, in my case I use 5W-30 since the book does say to use it. I may try the 5W-20 but I am more interesting in trying motorsilk first. http://209.200.118.63/index.cfm Well, for the record, when I first picked up my truck, there were no oil leaks. But after I removed the oil filter and replaced with Castrol Syntec 5w30, it started leaking like no tomorrow. I recently flushed the oil again (the colour was not pretty at all), and with a new filter, added Bardhal D1, and Engine Restorer mixed in with Castrol GTX 10w30. Well, its still leaking a tad bit, but not as much as before... I guess the thicker oil helps. Link to comment Share on other sites More sharing options...
wild91 Posted September 25, 2007 Author Share Posted September 25, 2007 well i have no oil leaks with GTX 5w20 Link to comment Share on other sites More sharing options...
adamzan Posted September 25, 2007 Share Posted September 25, 2007 no leaks with 20w50 in the summer and 10w40 in the winter in my 93. Dads 2000 is running 5w50 mobil 1 supersyn that we just put in at 125k, and its running like a top. Link to comment Share on other sites More sharing options...
