Reference Of Brake Liquid
WRL69
I have a 93 AT Pathy. In the maintenance instruction manual and in cap of brake liquid pot I read I have to use only DOT 3 liquid Brake. What hapen if I use DOT 4? What hapen if I mix both DOT 3 and DOT 4?
Regards,
I'd suggest using a good quality brake fluid since they're never very expensive.
Ate Blue or Gold are DOT 4+ which provides slightly better specs than DOT 4.
The cool thing about using the blue is that you know when the fresh fluid has made its way through when you start seeing a change in color. Next time you bleed your brakes you use the Gold and just watch for the clear fluid to come through. Easy!
