jj big shoe Posted June 9, 2007 Share Posted June 9, 2007 Can anyone ID this engine? I tried looking at pics of 300zx, Maxima, Quest, etc. and none seem to jive up. Its definately a VG30, but I think its from a JDM vehicle like a Gloria or something. I'd like to ID it to see if I could maybe use the intake and ditch my current TBI. Link to comment Share on other sites More sharing options...
88pathoffroad Posted June 9, 2007 Share Posted June 9, 2007 Pics are awful small to tell any detail. I dunno. JDM intakes were made differently than the US ones. Neat PCV tube thingie, heh. Link to comment Share on other sites More sharing options...
Casey.T Posted June 10, 2007 Share Posted June 10, 2007 VG30E... Swap out your Pathfinder Intake, fuel rails, exhaust, Valve covers, Oil Pan and pick up, Distributor and FLYWHEEL.... Dont forget the FLYWHEEL.... Or you will be pulling the engine again to swap it.... Link to comment Share on other sites More sharing options...
TerranoNZ Posted June 12, 2007 Share Posted June 12, 2007 I have the same sorta motor at home and wanted to use the intake.......BUT the manifold sticks past the block too far and would need a hole cut in the firewall for it to fit. I'd post pics but I got no computer at the moment. Link to comment Share on other sites More sharing options...
jj big shoe Posted June 12, 2007 Author Share Posted June 12, 2007 Ahh, so it seems. Maybe I'll throw the intake up on Maxima.org or something and see if anyone wants it. 'Cause folks get all hot over the JDM stuff, ya know? Link to comment Share on other sites More sharing options...
unccpathfinder Posted June 13, 2007 Share Posted June 13, 2007 VG30E... Swap out your Pathfinder Intake, fuel rails, exhaust, Valve covers, Oil Pan and pick up, Distributor and FLYWHEEL.... Dont forget the FLYWHEEL.... Or you will be pulling the engine again to swap it.... doesn't the dipstick needs to be swapped as well and change location...form the pic it looks like its on the correct side but maybe up a port or something...I know on that maxima conversion I had to switch sides completly... Link to comment Share on other sites More sharing options...
jj big shoe Posted June 13, 2007 Author Share Posted June 13, 2007 Dunno yet, the engine should arrive sometime next week. I figure I'll put them side by side and see what needs to be swapped. Link to comment Share on other sites More sharing options...
Casey.T Posted June 14, 2007 Share Posted June 14, 2007 doesn't the dipstick needs to be swapped as well and change location...form the pic it looks like its on the correct side but maybe up a port or something...I know on that maxima conversion I had to switch sides completly... Yep.... I had to do that as well... Link to comment Share on other sites More sharing options...
unccpathfinder Posted June 16, 2007 Share Posted June 16, 2007 Dunno yet, the engine should arrive sometime next week. I figure I'll put them side by side and see what needs to be swapped. yea what I did was pull the maxima engine apart (pulled off all the mtg hardware and all that crap then took 1 bracket off at a time and swapped it over to give it the pathy mounting...although some holes were not used b4 I had to spray them with PB and clean the threads B4 attaching the brackets... good luck shouldnt be too terrible Link to comment Share on other sites More sharing options...
jj big shoe Posted June 16, 2007 Author Share Posted June 16, 2007 Any idea what size bolts I should get to attach the new motor to my engine stand? Link to comment Share on other sites More sharing options...
unccpathfinder Posted June 17, 2007 Share Posted June 17, 2007 i cant remember right off the top of my head but I pulled 1 out and took it with me to the store...and with my stand i think i got 120mm long bolts they may be like an m12 x 1.5 or m8 x 1.25 but i'm not really sure Link to comment Share on other sites More sharing options...
jj big shoe Posted June 17, 2007 Author Share Posted June 17, 2007 Thanks, I'll prolly just get a set of both sizes then. Link to comment Share on other sites More sharing options...
