Cat Options
Zilverado
So I'm wondering what to do replacing my cat (it's rattling inside). Do I spend the big money ($300 to $400) and go with an OEM (with flanges) or do I spend under $100 for one I just clamp in. I was also debating just going with a straight pipe, but that would likely cause my O2 sensor to freak out and give me a "Check Engine" light?
What have the rest of you done?
Thanks in advance.
I replaced mine with a high flow cat but it was around $350. I forget who makes it. It came from a company in CA. I had two cats. I replaced the precat with a straight pipe.
I don't have a cat. Funny you should mention the o2 sensor though. I did the exhaust a year ago and there were no issues. my o2 sensor just went on me a couple weeks ago, i don't think its related though - probably an old sensor.
i know they make an O2 simulator for my car, but i have never heard of it for suvs although i havened owned an suv for very long.
The o2 sensor on a WD21 is located before the cat, so once (if) the cat is removed, the o2 sensor remains in place and operates normally.
Edited by LD50
That's a good point, I forgot about that. I'll make some calls tomorrow and see what I can find. Thanks for all the advice.
I found an old O2 sensor in my garage the other day if someone wants it. I won't be needing it.
:blink: does/did it work? if so, i'll take it!
I never tried it, its never been wired. PM me your addy and its yours. I have to go to UPS tomorrow anyway.
IIRC I think the directions for wiring is there too.
Edited by slimer
