mora2818 Posted March 17, 2007 Share Posted March 17, 2007 So I just hit the 120,000 mileage mark but the service manual doesn't go that far. I am wondering what if anything I need to do. I bought the rig with 110k and all the only thing I am aware of before that was done was the timing belt. So far in my possesion I have changed the PCV valve, Air Filter, Oil Filter, Plugs, and Coolant Temp Sensor. Keep in mind that I have a fairly annoying oil leak from the PCV system being plugged that has caused my RMS and FS to leak. Tax return should be here next week and this thing is going in the shop to get those fixed. So while under there it may be worthwhile to change some other parts. Thanks Kevin Link to comment Share on other sites More sharing options...
RWC5S2 Posted March 17, 2007 Share Posted March 17, 2007 I would change out all the fluids............transmission, both diff's, transfer case, radiator etc. Most likely needs a full tune-up if you haven't done that. Link to comment Share on other sites More sharing options...
vengeful Posted March 17, 2007 Share Posted March 17, 2007 Yeah, the 120,000 service is similar in nature to the 30,000 mile service. Link to comment Share on other sites More sharing options...
mora2818 Posted March 17, 2007 Author Share Posted March 17, 2007 What exactly is a "Full Tune-up"? I hear that term a lot and thought it just meant plugs, wires, fluids, filters. Kevin Link to comment Share on other sites More sharing options...
Pavelow Leaks Posted March 17, 2007 Share Posted March 17, 2007 Filters, belts (not timing), plugs, wires, cap & rotor, engine oil, tranny fluid, differential, trasfer case, take a grease gun to all the fittings, rotate the tires, wash it wax it & drive it! I probably forgot something, cuz I'm still up after bein at work all night..but thats pretty much what I consider a full tune up. Link to comment Share on other sites More sharing options...
ColinBen Posted March 19, 2007 Share Posted March 19, 2007 As a rough guess, if you change timing belt at 60,000, I would suggest another change at 120,000. Link to comment Share on other sites More sharing options...
yar1 Posted March 19, 2007 Share Posted March 19, 2007 Yeah, the 120,000 service is similar in nature to the 30,000 mile service. wouldnt it be similar to the 60k service? Link to comment Share on other sites More sharing options...
