120000 mileage mark
mora2818
So I just hit the 120,000 mileage mark but the service manual doesn't go that far. I am wondering what if anything I need to do. I bought the rig with 110k and all the only thing I am aware of before that was done was the timing belt.
So far in my possesion I have changed the PCV valve, Air Filter, Oil Filter, Plugs, and Coolant Temp Sensor.
Keep in mind that I have a fairly annoying oil leak from the PCV system being plugged that has caused my RMS and FS to leak. Tax return should be here next week and this thing is going in the shop to get those fixed. So while under there it may be worthwhile to change some other parts.
Thanks
Kevin
Filters, belts (not timing), plugs, wires, cap & rotor, engine oil, tranny fluid, differential, trasfer case, take a grease gun to all the fittings, rotate the tires, wash it wax it & drive it! I probably forgot something, cuz I'm still up after bein at work all night..but thats pretty much what I consider a full tune up.
