94XEfor1K Posted March 9, 2007 Share Posted March 9, 2007 So i searched for a while but didn't find quite what I was looking for...at any rate. my pathy sits a tad lower in the front, which I know some people desire. But, my two front tires on the inner edge are totally bald and starting to tear. (Obviously I'm getting new tires next week and not driving it until then) good old PO's. I found reciepts for the shocks being done about 60K ago though they are just crappy mountain ryder I think. What I'm wondering is could crappy shocks be the cause? Or does the torsion bar need to be adjusted? (I guess that wouldn't really have anything to do with the tires but that could be why it sits lower in the front right?) Obviously I'm new at this thanks for your patience and help :oops: Link to comment Share on other sites More sharing options...
GrimGreg Posted March 9, 2007 Share Posted March 9, 2007 Shocks won't cause it, T-bars might. You need to have it alligned. Wear like you are describing is usually caused by the camber being off. When the T-bars are adjusted or sag, they can change the camber (along with toe and caster). Link to comment Share on other sites More sharing options...
mws Posted March 9, 2007 Share Posted March 9, 2007 What he said. Inner shoulder wear is usually indicator of toe out or improper camber. Link to comment Share on other sites More sharing options...
Casey.T Posted March 9, 2007 Share Posted March 9, 2007 GG If your planning on doing any suspenstion upgrades you might want to look into having a Goodyear Lifetime Alignment... I know I like mine... If you get the Lifetime one, and you do a Suspension Lift, they will re-align it for free... You snap a TRE and put a new one on yourself... they re-align it for free again sly Link to comment Share on other sites More sharing options...
Simon Posted March 9, 2007 Share Posted March 9, 2007 A bad CL can cause your tires to look like this / \ and as well will cause inner tire wear. Also, ball joints, tie rod ends.....all things that will be detected before any decent shop does an alignment. Link to comment Share on other sites More sharing options...
94XEfor1K Posted March 9, 2007 Author Share Posted March 9, 2007 Nice...that doesn't sound so bad...Now to find some good tires I'm only thinking of a 2" BL so I think I'll go with the 10.50X15X31 I think it is...bfg a/t unless I can find m/t's for close to the same price. Typically about a $20 diff per tire...that's not too spendy I guess Link to comment Share on other sites More sharing options...
