ILoveMyPatty Posted December 16, 2006 Share Posted December 16, 2006 I know there's a topic about in the How To section, but it's fairly unactive and the link seems to be dead. I need to know how to completely reset the system, it got set somehow so the immobilizer thing is always on, and I can't start the Pathy. I pulled the fuse so I can drive it, but I hate having to unlock with the key all the time. Any help would be appreciated. Thanks! Link to comment Share on other sites More sharing options...
unccpathfinder Posted December 16, 2006 Share Posted December 16, 2006 disconnect the battery overnight? Link to comment Share on other sites More sharing options...
ILoveMyPatty Posted December 16, 2006 Author Share Posted December 16, 2006 Overnight? Hmm, possibly. I haven't tried that yet. Doesn't that do something with the fuel pump and or ECU? Some sort of reset type of thing...? Link to comment Share on other sites More sharing options...
Banshee162 Posted December 16, 2006 Share Posted December 16, 2006 it will reset any codes in the ecu Link to comment Share on other sites More sharing options...
ILoveMyPatty Posted December 16, 2006 Author Share Posted December 16, 2006 Hmm okay. I need to figure out how to reset the alarm though... gah, I hate it. Link to comment Share on other sites More sharing options...
5523Pathfinder Posted December 16, 2006 Share Posted December 16, 2006 Try unplugging the control unit under the drivers seat for a few minutes. You should be able to run the vehicle with it unplugged. When mine went out last year while driving, I just unplugged it until I could replace it. Everything else worked fine. If you cant turn it off with the key fob, try both key cylinders lock and unlock. Or set off the alarm then immediatly put the key in the ignition and turn it to on. That should stop it. Link to comment Share on other sites More sharing options...
BLouisGod Posted December 16, 2006 Share Posted December 16, 2006 Id reprogram the whole system with your keyless remote and all. I believe I accessed the control unit under the drivers seat, pressed and held the botton covered by small paper until it clicked, then held the lock button on the remote until the control unit clicks. The remote should work and all should be reset. my alarm would go off for no reason a couple times a month; my neighbors still goes off lol - I havent told him about the reset button, its to funny hearing him curse up a storm Link to comment Share on other sites More sharing options...
ILoveMyPatty Posted December 19, 2006 Author Share Posted December 19, 2006 There's a control unit under the drivers seat? All there is under there is a plate with a lock on it (for a key)... I think the PO had a phone in there, under the seat (there's a mic on the door frame, right to the left of the driver. Do you have a picture of this unit? Or can you get one? All I can find is a black Clifford box, under my dash. Link to comment Share on other sites More sharing options...
88pathoffroad Posted December 19, 2006 Share Posted December 19, 2006 If you have the stock alarm, it's under the driver's side seat. Get under there and look again. Link to comment Share on other sites More sharing options...
BLouisGod Posted December 19, 2006 Share Posted December 19, 2006 Its about the size of a portable cd player and its located close to the center console. its got a little paper nissan label covering the button im talking about. Link to comment Share on other sites More sharing options...
k9sar Posted December 19, 2006 Share Posted December 19, 2006 and a little wire antenna Link to comment Share on other sites More sharing options...
ILoveMyPatty Posted December 20, 2006 Author Share Posted December 20, 2006 Hmmm, I'll have another look, but the phone mounting plate takes up alot of the room. I didn't see anything else... but I'll take another peek Link to comment Share on other sites More sharing options...
BLouisGod Posted December 20, 2006 Share Posted December 20, 2006 You really cant see it if you roll the seat up, youll have to get down there and look in and feel around for it, or you could remove the drivers seat. It is there though if you have the factory system. Link to comment Share on other sites More sharing options...
ILoveMyPatty Posted December 21, 2006 Author Share Posted December 21, 2006 I've looked really good under there, with a flashlight, from the front and from behind. I checked both seats. All that is there is an air vent and the plate for the phone. Link to comment Share on other sites More sharing options...
5523Pathfinder Posted December 21, 2006 Share Posted December 21, 2006 Here is a pic of the alarm control unit. As you can see, its just on the inside of the heater duct. It may be covered under a piece of the carpet. Link to comment Share on other sites More sharing options...
ILoveMyPatty Posted December 21, 2006 Author Share Posted December 21, 2006 Ahhh, cool. Thanks man. I'll go take another look I was looking from the outside, not the inside, so I didn't see what was on the other side of the duct. I'll have a looky loo and see what I can find Link to comment Share on other sites More sharing options...
ILoveMyPatty Posted December 21, 2006 Author Share Posted December 21, 2006 Nope, definitely nothing there. ARGH. Thanks for the help everyone. Link to comment Share on other sites More sharing options...
