fishead Posted November 26, 2006 Share Posted November 26, 2006 OK, I am having enough problems with this that I am starting to believe it is not just me. To check the oil when getting gas, I pull out the stick, wipe it off, put it back in, pull it out again, and the dipstick is smeared. Funny thing is, sometimes there is a dry spot on the stick near the end. What the carp? Is it full, is it empty? This was one of the things that helped bake my previous engine. How do y'all get a good measurement? If I put in an oil pressure gage, will it be a good indicator of when I need to do something? Link to comment Share on other sites More sharing options...
yozsi Posted November 26, 2006 Share Posted November 26, 2006 if you have a dry spot at the end, you are low on oil. Link to comment Share on other sites More sharing options...
94extreme Posted November 26, 2006 Share Posted November 26, 2006 you need to check the oil cold and when the truck has sat for sometime.. what you're getting is a reading of oil being thrown around.. my guess is with yozsi here.. you're probably empty but check it the correct way to make sure. Link to comment Share on other sites More sharing options...
Slick Posted November 26, 2006 Share Posted November 26, 2006 i usually check my oil when i get to work... i let the truck sit for about 15-20 mins then i go out and check the oil. i usually get a much more accurate reading than i do if i check it immediately after i turn the engine off. i usually "dip" the stick 3 times .. yes... the dipsticks are a common complaint on these trucks..you are not alone Link to comment Share on other sites More sharing options...
94extreme Posted November 26, 2006 Share Posted November 26, 2006 what's wrong with you all's dip sticks? i think the one on our trucks is one of the best out there.. hmm.. never had any issues with reading it... hmm Link to comment Share on other sites More sharing options...
sammyb33 Posted November 26, 2006 Share Posted November 26, 2006 same here MZ....never had problems, dont leak a drop of oil either... -sam Link to comment Share on other sites More sharing options...
mikemike Posted November 28, 2006 Share Posted November 28, 2006 i leak a lot.. and i burned my hand on the exhaust Link to comment Share on other sites More sharing options...
Slick Posted November 28, 2006 Share Posted November 28, 2006 i leak a lot.. and i burned my hand on the exhaust as long as only 1 of you "leaks"......... Link to comment Share on other sites More sharing options...
RedPath88 Posted November 28, 2006 Share Posted November 28, 2006 i leak a lot.. and i burned my hand on the exhaust sssh Don't let B hear you say that Where is the Pathy leaking... it IS the Pathy that leaks, right? Link to comment Share on other sites More sharing options...
