93PathfinderWA Posted September 14, 2006 Share Posted September 14, 2006 Hey i have 1 stuck bolt that refuses to move at all. I have tried PB blaster, liquid wrench, and alot of pushing as hard as i can on the stupid thing and it wont move. My dad said i could get a torch and heat it up. Would heating up the bolt after PB blaster cause a fire cause the can says that it doesnt evaporate, so where does it go? Thanks. Link to comment Share on other sites More sharing options...
94extreme Posted September 14, 2006 Share Posted September 14, 2006 no fire but be careful anyway. it goes into the frozen threads.. sometimes you have to let it work for quite sometime.. re apply PB every day or so.. Link to comment Share on other sites More sharing options...
mws Posted September 14, 2006 Share Posted September 14, 2006 It may burn a little, but not too much. Keep a soaking wet rag at hand and a fire extinguisher nearby, but I have been able to blow out what small fires I've had. Link to comment Share on other sites More sharing options...
Mr. Pickles Posted September 15, 2006 Share Posted September 15, 2006 Also, have you tried a breaker bar or a cheater bar over the ratchet? Maybe you need just a tad more leverage. Easy goes it though, ya don't want to break the bolt. Where is the bolt, anyways? Link to comment Share on other sites More sharing options...
93PathfinderWA Posted September 15, 2006 Author Share Posted September 15, 2006 Thanks about the fire notice, i did not want anything to go wrong since it is under the car. Also, have you tried a breaker bar or a cheater bar over the ratchet? Maybe you need just a tad more leverage. Easy goes it though, ya don't want to break the bolt. Where is the bolt, anyways? Yah i was using a breaker bar. It is holding on some smittybilt steps that i have. The Bolt also holds on something else so i dont want to break it. I will just wait till my dad gets home though. Link to comment Share on other sites More sharing options...
the rig Posted September 16, 2006 Share Posted September 16, 2006 if you use the "blue tip wrench," heat the surrounding metal, not the bolt itself. Metal expands when heated, and inversly, retracts when cooled. hth Link to comment Share on other sites More sharing options...
94extreme Posted September 16, 2006 Share Posted September 16, 2006 you never really said what bolt this was.. my policy anymore is that if i can put another in the same spot i am cutting the old one off.. i have waisted enough time and have bled enough too. Link to comment Share on other sites More sharing options...
Mr. Pickles Posted September 16, 2006 Share Posted September 16, 2006 you never really said what bolt this was.. my policy anymore is that if i can put another in the same spot i am cutting the old one off.. i have waisted enough time and have bled enough too. I'm with ya buddy. Link to comment Share on other sites More sharing options...
93PathfinderWA Posted September 16, 2006 Author Share Posted September 16, 2006 Yah i am just going to leave it for now and figure it out when my dad gets home. Link to comment Share on other sites More sharing options...
