A-Pillar Gauges
vengeful
I'm looking to add some gauges to my truck to more closely monitor conditions as it gets older.
Trans Temp, Oil Pressure, EGT, Volts, Water temp, Oil Temp are the ones I'm looking to get.
I'd like to mount the Trans Temp, Oil Pressure and Volts on the A-pillar and the EGT, Water and Oil temps in the center stack. The center stack is easy enough, and I can mount them where the HVAC controls are after I finish relocating them.
However, I was unsuccessful in finding A-Pillar pods for gauges for the R50. Has anyone installed some there? What pods did you use? How'd you go about doing it? Pics?
I did find a "universal" APC pillar pod, but it's for 2 1/16" gauges.
The gauges I wanted to use are 2 5/8". :sniff:
I suppose I could use 2 1/16" gauges if it came down to it. And I'm sure I could make that thing work, and if not, I bet I could return it at the very least...LOL.
