ticker Posted August 11, 2006 Share Posted August 11, 2006 I drove out to pennsylvania last weekend and noticed that the shifter shaft on the 4wd t-case got really hot. Is this normal? If not what to look for? The temperature was in the 80's. I have an aftermarket tranny cooler that bypasses the stock one. Automatic Transmission any help would be appreciated, thanks Link to comment Share on other sites More sharing options...
94extreme Posted August 11, 2006 Share Posted August 11, 2006 on way long trips it will get hot but if you think it's not normal at least check the fluids.. and wait for other ideas as that's all i have. Link to comment Share on other sites More sharing options...
Precise1 Posted August 11, 2006 Share Posted August 11, 2006 Mine heat up quite a bit on a long trip also. All I can guess is that it is heat from the motor/exhaust being blown back. Lets face it, right under the truck is not a hospitable area... My MT doesn't get hot, and the T-case isn't being used. B Link to comment Share on other sites More sharing options...
solid snake Posted August 11, 2006 Share Posted August 11, 2006 try changing the fluid. it may be worn out. newer fluid is more viscous and have better agents than old. Mine gets pretty hot too. Like B said, it's not a real good place due to the exhaust, tranny, and motor. Link to comment Share on other sites More sharing options...
Slick Posted August 11, 2006 Share Posted August 11, 2006 Mine heat up quite a bit on a long trip also. All I can guess is that it is heat from the motor/exhaust being blown back. Lets face it, right under the truck is not a hospitable area... My MT doesn't get hot, and the T-case isn't being used. B ditto Link to comment Share on other sites More sharing options...
ticker Posted August 11, 2006 Author Share Posted August 11, 2006 Thanks Guys and Girls, I thought that it was maybe due the way things are set up and the missing cat shield doesn't help. The fluids pretty new, I checked them during the trip and no funky smell or anyrthing so I'm not going to worry about it too much since other people are having the same experience. :bow: Link to comment Share on other sites More sharing options...
k9sar Posted August 11, 2006 Share Posted August 11, 2006 my shift levers get kinda hot too but I've never thought much about it. Of course, I just went through having to put out a fire in my carpeting caused by excessive heat. Link to comment Share on other sites More sharing options...
cdhicks99 Posted August 11, 2006 Share Posted August 11, 2006 I've been driving without a console since the new tranny went in, and I have to keep a shop rag packed in the shifter hole or it'll burn my leg. Link to comment Share on other sites More sharing options...
k9sar Posted August 11, 2006 Share Posted August 11, 2006 I have to keep a shop rag packed in the shifter hole or it'll burn my leg. that somehow sounds a bit perverted but I'm not sure why Link to comment Share on other sites More sharing options...
cdhicks99 Posted August 11, 2006 Share Posted August 11, 2006 The air blowing in is seriously hot, hot, hot! Link to comment Share on other sites More sharing options...
k9sar Posted August 11, 2006 Share Posted August 11, 2006 I'll bet. Link to comment Share on other sites More sharing options...
Precise1 Posted August 12, 2006 Share Posted August 12, 2006 Try to focus k9sar... B Link to comment Share on other sites More sharing options...
