88blk4x4 Posted August 1, 2006 Share Posted August 1, 2006 hey ya'll I was going to put pics of my pathy on here for everyone to see, but the tranny went out...got no reverse...tries to pull forward in N.....how hard is it to replace a auto tranny?? I bought one for parts that I'm thinking about fixing instead, it needs rod bearings.....any advice for a new pathy owner?? Link to comment Share on other sites More sharing options...
John Boy Posted August 1, 2006 Share Posted August 1, 2006 OK new rules, if your tranny goes out and you post it you have to tell us .....How many miles on the tranny? and if it has a tranny cooler? Link to comment Share on other sites More sharing options...
cdhicks99 Posted August 1, 2006 Share Posted August 1, 2006 I just replaced mine a couple of weeks ago. Took 6 days to drop, 4hrs to bolt her back in. Not hard at all just get some looooong extensions. Link to comment Share on other sites More sharing options...
88pathoffroad Posted August 1, 2006 Share Posted August 1, 2006 Yeah, it's more of a "think around the obstacles" type of task than it is hard work. Mine's waiting for $$ so I can replace fluids, gaskets and install headers at the same time is all, I took out the other one I had in a couple of days easy work. A tranny jack or cradle would be a big help on this one, the trans/t-case combo is HEAVY! Link to comment Share on other sites More sharing options...
cdhicks99 Posted August 1, 2006 Share Posted August 1, 2006 About 350 lbs or so! Link to comment Share on other sites More sharing options...
mws Posted August 1, 2006 Share Posted August 1, 2006 got no reverse...tries to pull forward in N..... Keying in on this statement.... Is it possible you just have a misadjusted shift lever linkage??? Link to comment Share on other sites More sharing options...
88pathoffroad Posted August 1, 2006 Share Posted August 1, 2006 Or a leaking shift solenoid. If a seal went, it'd likely leak fluid through the one and affect the other solenoids. I'm not a tranny pro, though! Link to comment Share on other sites More sharing options...
88blk4x4 Posted August 2, 2006 Author Share Posted August 2, 2006 OK new rules, if your tranny goes out and you post it you have to tell us .....How many miles on the tranny? and if it has a tranny cooler? it has about 126k on it....and no tranny cooler Link to comment Share on other sites More sharing options...
88blk4x4 Posted August 2, 2006 Author Share Posted August 2, 2006 (edited) Keying in on this statement.... Is it possible you just have a misadjusted shift lever linkage??? well, I was driving it and it sorta went clunk and it wont shift right if you can get it to go....I drained the fluid and it had ALOT of metal in the bottom of the pan....the trans shop said it probably welded the clutches together..... Edited August 2, 2006 by 88blk4x4 Link to comment Share on other sites More sharing options...
94extreme Posted August 2, 2006 Share Posted August 2, 2006 well, I was driving it and it sorta went clunk and it wont shift right if you can get it to go....I drained the fluid and it had ALOT of metal in the bottom of the pan....the trans shop said it probably welded the clutches together..... yup. mine did that too. rebuild time. make sure you add an external tranny cooler and bypass the stock one.. lot's of threads about this in the garage and year specific forums. Link to comment Share on other sites More sharing options...
