93xe
Everything posted by 93xe
  1. i actually meant to order the back pockets, i just forgot. that is exactly where my ds seat was torn, i shoved some foam in it and duct taped it shut before putting on the covers. it took about 3 weeks from order to delivery, and i believe they were $255 shipped to my door
  2. thanks pezzy the seat covers fit incredibly well, they are specific for the seats in the pathy. and yes i ordered them directly from the wet okole site the headrest cover and seat back cover both attatch with strong velcro the bottom cover uses 3 straps, 2 that run front to back and one side to side it seems like to get the best fit the seat needs to be removed and the plastic side trim pieces removed to properly run the straps until i get to that, there is a little bit of bunching in the material on the bottom sides, but only because i ran the straps over the inside trim. other than that, they look and feel awesome and fit great, i would highly recommend them to anyone looking for a good cover. I went with just the fronts because my ds seat had a tear in it, and they were fairly pricey, but the back seats will be covered by summertime
  3. 03 SE roof rack, crossbars, and front valence bolted right on in place of the factory '97 rack with longer bolts, 20 minute install wet okole basic seat covers (fronts only) they fit really nice and the gray looks just like the factory interior color, I still want to take the seats completely out of the truck to snug them down better on the bottom half Flowmaster 50 series w/ 2.25" cat back and a giant tip im happy with the way the exhaust turned out, its nice and deep without being overly loud or annoying the guy who did it put the tip on without asking me, its ok but i will probably change it out for a smaller side exit one, plus it looks like it will get in the way if I add a hitch too cold out to get any decent pics
  4. I have a compustar pro on my '97. Its a 2 way alarm/remote start combo, and I love it. There are a few brands that are manual trans compatible but compustar is definitely my favorite (i have been through many alarms/remote starts) Neutral safety switches are standard on pretty much all remote starters. They are really not that hard to install if you are familiar with electronics, specifically 12v. If you are not, definitely go to a shop and have it installed. For a remote start/alarm combo, you will need to find and hook up the following wires... 12v constant Ignition Accessory Starter (x2) Door Trigger Tach Lock Unlock Domelight (if you want this feature) Brake Parking lights Horn (if you want instead of or in addition to siren) If your pathy has an engine immobilizer there are some more depending on the type of bypass used
  5. If i remember correctly there should still be the two screws on the bottom on both sides, angled slightly downward. Then pull the vent bezel (the top section) off and there will be 2 more screws before you can remove the trim around the radio
  6. yea, i wasn't sure if the earlier ones came with those options or not... thanks for the response
  7. I scored a set of illuminated driver and passenger side sunvisor/mirrors with the homelink from an '01 SE, Just wondering if anyone knows if all rR50's are wired for these, mine is a '97 xe and i just haven't had a chance to look in the headliner anywhere for the wires. BTW each one had a simple white 2 pin plug. Thanks in advance -Josh
  8. My fogs on my '97 are shot. Lenses have chips and cracks, screws on the back are completely rusted out, etc etc. Has anyone replaced their factory fogs with something similar that fits in the same location?? I have a set of PIAA h3 ion yellow bulbs i plan on throwing in whatever i get, so i really only need a good casing/lense combo. I checked around and factory replacements are going for around $50 a piece on ebay, id rather put the money into a good aftermarket set. Anybody have pics of a replacement on their pathy?? Thanks
  9. on my '97 automatic, speed sense was yellow/white wire at the cruise control module in the driver's side kickpanel
  10. Got these on a few weeks ago BFG AT KO 31x10.50x15 from 4 wheel parts 2000 Xterra 15x7 stock alloys from craigslist pretty cheap OME Nitro shocks from 02 silverpathy (thanks again)
  11. yes you will need relays if you get a name brand alarm like a dei product (viper, python, rattler and more) it should come with a door lock module (part #451m) that will allow you to interface the actuators w/o additional relays. If you bought a cheap ass alarm you will need multiple relays to get them all to work
  12. the day i got her... edit by 88: resize, please...600-700K per pic is WAY too big
  13. it sure does support aux video in...and great idea that will have to be added to the project list
  14. gps antenna next to xm antenna on back of the roof that is all
  15. dual drives, one for cd/mp3 one for dvd/nav (so you can navigate and still use a cd/mp3 disc)
  16. source menu...also does sirius with nav traffic
  17. got a great deal on this slightly used from a coworker, couldn't pass it up Eclipse AVN550 cd/dvd/nav
  18. end result...only the wire for the sub (which just sits in the back for now) exposed, and i can still take out the sub, fold down the seats, and not worry about messing up my equipment.
  19. lid closed, but i still need to cut out the bottom of that pocket so the lid closes correctly. I also shot some screws on the sides because that pocket just snaps in and rattled around without them
