Everything posted by BoneZ
Just thought I would let you know that the shimmy was coming from one end of my centerlink. The hole that goes through had became egg shaped and was allowing it all to shift around while driving. when the pathfinder was parked you could not feel any movement in it, it was found because i started taking all of the steering apart to find the problem. This is not recommended but since I had no money at the time i found the problem I drought it to a friend that runs a fab shop he welded the area and re machined and drilled it for me 4 free. After putting the front end back together and doing a driveway alignment the pathfinder drives straight with no shimmy. Before anyone starts going off on thats not a safe fix, I am going to replace it on payday and keep this one as a spare part for on the trails. be safe and I hope this helps some others with the same problem.
On the metric tire size thing make sure to consider the rim size, On metric tires say you have a 305-70 r15 and a 305-70 r17. the 305-70-r15 will be about a 33" tire, while the 305-70 r17 will be about a 34" tire. Just want to put this out there to try to clarify the confusion.
Yes it sounds like we have the same problem I will look through those things this weekend thanks for some more ideas. If anyone else has any suggestions please let me know.
The shimmy I am getting in my steering wheel is not noticeable except in the steering wheel, Passengers can not feel the shimmy at all, The pathfinder still drives straight, but the steering wheel shimmy's almost 1/2" each way as you drive, It seems to have a little less shimmy when you are turning over about 45 degrees. I was hoping someone can help point me in the right direction. At first I thought ball joints, tre's or wheel bearings but can not find any play in them. before you say use the search function I tried and found several post but I could not find one about the steering wheel shimmying and the vehicle still tracking straight. If anyone knows of a post describing a problem like this please post a link. Thanks for your time everyone.
Thanks for the quick reply guy's. guess this is what I will do. On another note, what axles are about the right size for a SAS in these pathfinders besides a waggy axle just want to know what I should be watching for a good deal on. Or can someone post a link to a post with this info on it.
I was going to do a 3+3 and 33" tires but once i really got into looking at the suspension and steering assembly, I have changed my mind on that, I will install a 3"bl and try to run 32" tires for now want to know how much trimming will be needed, Then hopefully I will be doing a SAS next winter. I will not have time and money to do it this winter after buying rig fixing broke parts and installing locker, body lift, a few steering upgrades, so it will have to wait tell next winter. Any info on how much trimming would be nice pics of rigs with 3"bl and 32's would be even better.
You are all right about 1 thing they would not completely go under, Ford says they have the money to make it through yay the least inovated most falling behind company can survive because they dont upgrade they products like the others, Gm will close down in America but will live on through its Brazilian counterpart. Note the GM Brazil is really a separate entity from America GM, They do not use much American made goods in there production. And use mostly smaller engines like 1.6-2.4 style engines and are mostly lp & NG engines. Chrysler Is in big trouble, I love dodge my main vehicle is a dodge 1/2 ton 4x4, but the company spent way to much of there research money making the electric engine transmition that is due to release in 2010, for those that dont know about this it is a eletric engine built into the transmition you dont even have to turn on your engine to drive around town, but for highway you can tap the power of the heme in 4-6 or 8 cylender mode depending on the power you need. That transmition would change the way more efficant vehicals are made world round. But Chrysler has been in trouble for a while and trying to sale out GM was going to buy them but They did not have the money. And like I said before not only will the car company's die but company's that make ECM's, wiring harness stuff, 100's of machine shops that make there parts, Several of the Foundry's in America are keep afloat by the car company's as well. If you tried to list every kind of company that will be put out of business by the car company's dieing you would be there for longer then 90 percent of the population realizes. I am probably overly opinionated on this though as I am one of the millions of people that will lose there jobs if they go under.
There will still be marine and industrial engines being built if they go under it will just be stuff from other country's not supporting all of are people that will be out of work, And so you know GM engines are used in the majority of industrial equipment, I mean even some toyota forklifts have gm engines in them. The marine world would not care if ford went under as There is no one trying to make fords work for marine applications anymore. The last company that was doing that was redline marine but they went under already. And for the people saying that the American car company's have not been moving forward in tech are all wrong, I mean comparing the engines from 6 years ago to now we produce 2 times the power with less gas and have better emitions. Two of the most prestigious awards in the industry are the Motor Trend Car and Truck of the Year, as well as the North American Car and Truck of the Year. These awards are given by those that study the cars/trucks for a living - they are unbiased. The awards are based on design, technology innovation, ride, handing, safety, performance and value. As the 2009 awards have not all been made. You'll note that GM received 5 of the top 8 positions. There's a lot of competition out there - and most of them are very good.
What allot of people are not realizing is if the car company's go under it will be a chain reaction. I know if GM goes out of business I will be without a job, ( i work for a company that dose marine and industrial engine builds) It will not only be the car company's, company's such as delphi, bosh, allot of lift truck company's will be out of business, that is to just name a few, There are 1000's of company's in the united states that if the big 3 go under will sink with them. Just thought i would give my 2 cents.
work for a GM OEM yes the ls1, lq4, ly6, lsa, and lst, (all versions of 6.0-6.2l) all run 15-20 degrees hotter then the older engines like the 5.7(350) 4.3(262) and such.
Thanks allot Simon That is right what I was looking for.
Can anyone show me a picture of how the grassroots centerlink is any different then the stock center link in the pics on grassroots they look just like the stock can see no difference. If anyone can post a pic of it it would be a great help, Thanks for your time.
No, There is a bar with a balljoint type thing at 1 end that holds to the axle or lower contol arm mattering on make.
I Was thinking about making one out of a stock center link and I know they built it out of one, I am a decent welder and fabricator. That is why I was looking at pictures I should have phrased that better, I just want to see how others have addressed the design flaws.
I have been looking at after market centerlinks like the L&P and the one they sale at grassroots, I wanted to know if anyone has a picture of how these are different then the stock ones, All of the pictures of them I can find online they look like the same thing as stock. If anyone has some pictures of these please post a few.
So have you got the part and done any testing, thought you might have some results after 7 mounths.
When When I bought my pathfinder for 800 dollars it had a similar problem. The previous owner replaced allot of stuff trying to fix it with no luck so I got IT at a very good price. When I went through the truck I found that the passenger side compression rod was bent right where it goes through the cross member area.(not sure its really a cross member it goes through but you can see where it mounts to). It was bent right in the center of that part so it was really hard to see I noticed by the threaded area sticking out the back not being even with the shaft towards the front. After replacing this compression rod (10 dollars at the local u-pull it) The pathfinder rides great. You might want to see if yours are bent or broke anywhere. On my pathfinder you started to feel it at about 45mph but it did not become intense in tell around 60mph.I was not hearing the clunking noise you describe from the rear of the vehicle though.
Oh I thought L&P was still around because I was on there web sight at L&P but if they no longer exist I will look Into HooHaa. Do you have a link for there Products.
Will the L&P steering setup hold up to 33's and real offroading or am I better off custom fabbing up a setup, Was looking into the steering stuff and there system looks allot stronger then stock, I just dont know if it will hold up to 33" tires and real offroading.
I need to keep it street able enough to drive it to the trails so Im probably not going to do that, If I cant make a steering setup work that well I will go to hydrolic steering. I would prefer not to do this because of the cost and how cops seem to notice it and herase you about it even though there is no law against it here in oregon. I am in the process of looking for a pathy in a junkyard to pull all of the steering stuff out of to use for a guide to make a new setup.
Thanks for the reply Last build sheet I saw on your pathy was listed at 33-12.5, But if you can fiit them now thats good then I should be able to run the Iroks with the 3+3 And some triming, What offset are you running on your rims. Was there any other mods That need to be done to fit these tires. I know I will need to upgrade the steering parts but I plan to custom Fab up some beefy rods and brackets for that. Any insight on this would be helpful as I plane To do allot of the mods to this vehicle all at 1 time.
88's truck is a 2 door not a 4 door and he is running 12.5 wide, and the iroks smallest size is the 33-13. I will probably just end up running a different tire to be thinner. It Is just the IROKS are the best offroad tire I have ever seen. They put the regular swampers to shame witch stomp on most the competitors with ease offroad.
I want to know if anyone can tell me what I have to do to fit 33-13 tires they would be on 17" rims, going on a 91 4 door pathfinder. The tires i want to run are the IROKs. Also what back spacing would be needed. Can I fit them with a 3"sl and a 3"bl and some trimming or would I have to do more. If anyone can let me know it would be very helpful I am getting ready to build this rig for trail runs. I normally wheel my 2001 dodge ram but It is to big to fit in some of the trails out here in Oregon, not that I cant get it in there but they do not allow rigs over a certain width in them. So I thought a pathfinder would be a nice trail rig, Hope someone can help answer this for me thanks.
