Everything posted by PFCFNG
I had a 126 in a 55. On a 24 year old motorcycle!
Aftermarket CD And the VIN plate is spot on, doesn't seem to have been tampered with. Someone just switched the door. I should have looked at it closer. Thanks for all the help.
I wouldn't let him give it to me. Not enough ground clearance. (And the cops follow me enough as it is)
Roll into one of the self service car washes with the power washer stuff. Engine degreaser then high pressure rinse. Will get the oil and everything off really easy.
Manual transmission TSB
PFCFNG replied to madkiwi's topic in Technical Service Bulletins & Recall Information
Anyone? -
Thank you, the wiring diagram is a big help. Alkorahill, you think you can get a mechanical schematic or something along those line on Mon?
What do you mean without the clutch engaged? Like with the trans in neutral but without the clutch pushed in? (tried searching, couldn't hit the right combination of keywords I guess)
I have a switch on my dash to the left of the steering wheel by the hazards that reads "interlock". I press it and nothing seems to happen. Anyone know what is supposed to happen?
Can anyone provide me with a wiring schematic or technical drawing of the different components for teh rear wiper? Mine does not function (hasn't since I got my pathy) and I would like to fix it. Thank you for the help.
Can't tell. The sticker has been torn up a little bit.
I have an XE and love it. Only thing I wish I had was the tire rack on the hatch.
Ok, back on topic. The issue was the tires. I was comparing the tire size to the door sticker, which is for an SE same color and year as my rig. My VIN reads as an XE. So either just the sticker was replaced or that whole door was. Who knows. Thanks all for your help. (In michigan the signs are green)
Be careful. It WILL throw off your speedometer
$500 cash if you change my water pump/timing belt on my 90 pathy!
PFCFNG replied to NaturaTek's topic in General Forums
If only I was closer... -
Let's add to the madness. I have a friend of mine who is a local police officer and he was bored the other evening. My speedo is spot on at 25mph (speed limit), and 45 mph (ran out of road). But at the same time I drove with a friend of mine on the freeway and at 70mph my speedo is off by about 13 (+/- ~2). Does this make sense to anyone?
Does anyone know of a way to read/decode the VIN to determine for sure? Or where the SE and XE dealer option packages?
The Speedometer does not jump, I have some random off brand all terrains the PO put on, they are 31's. Which Pathy's came stock with 31's and how can I tell which kind my Pathy is? Most of the factory badges have been removed. I have an LSD (tested by gravel peel-out method), manual windows and locks, V6. The spare is inside the hatch, not on an exterior rack... In Mi you can't exactly contest the radar, the judges get a little pissed if you waste their time trying as well. Plus this particular officer was "nice" enough to write the ticket as "impeding traffic" which is $50 more for the fine but doesn't have any points. I can't exactly fight it and don't really want to. But I would like my speedo fixed.
Ok, I managed to get a ticket for doing 83 in a 70. But my speedometer read 70 cause I spotted the speed trap a quarter mile away and MADE SURE my speed was 70. What can cause this great of an error in the speedometer other than tire size? The tires on my Pathy are the stock size (according to the local tire shop anyhow).
Still beats tearing apart the whole exhaust
As far as I go, remans are baaadddd news. If you want a reman, buy a kit and rebuild it yourself. You can trust your own work. Otherwise buy new. I would try Autozone. They have a "Duralast" brand that has a lifetime warranty, no questions asked.
Let me know how much you end up spending. I will probably do mine myself once I free up the cash and the workspace.
Sounds like the same problem. So far if I let her warm up and just drive around town its fine. When it's cold it makes racket. If I cruise on the highway for a long time it makes worse racket. Seems like driving at 80mph for an extended period of time allows one part to expand from heat more than another.
I second the whole "jump it" idea. While you git the hood up, check to see if you blew any fuses for the starter.
