super6turbo4
Everything posted by super6turbo4
  1. I installed mine in my '94 using the front diff out of a '95 that I had. Some late '95s also had 2 pinion carriers. LOKKA can tell you if you give them the VIN.
  2. I received a separate bill for customs fees about 2 weeks after I had the locker. My kit for the '95 did not come with a cross shaft.
  3. Lester. I can't see where you are. I have an R180 out of an 06 frontier in Charlotte NC if you are near me.
  4. Those of you interested need to call LOKKA and give them your VIN. I had to swap the diff from a 95 I had in order to put one in my 94. Not all R200 carriers are the same. Some are 2 pinion and some are 4. They only offer a locker for the 2 pinion.
  5. The only reason to go through mud is to get to the rocks.
  6. They look fine. Not hard to install just time comsuming.
  7. I run 285 75 r16 with only a suspension lift. All it takes is an air saw.
  8. That is exactly why I carry a complete spare shaft. If you have a PullApart near by you can get one for about $12.
  9. Yes if you don't mind cutting. As for power. I think they are underpowered to begin with so with stock gears and 33s it's a dog, but that's another reason I trailer it.
  10. All the pics I have are here. http://www.nissanpathfinders.net/forum/index.php?showtopic=18427 I will try to get a few more this weekend.
  11. Since the axle moves in a rearward arc you only have to trim the rear of the wheel opening. The only time a tire has hit near the door was when I bent a lower control arm.
  12. I'm guessing that was directed toward me. I bought some AC UCAs used. If I had spent real money on them I would be pissed. The fabrication sucks.
  13. Here you go. 33s with no body lift. Just suspension lift and trimmed fenders.
  14. No problem. I also like the stretch kit because I can mount my side lights to it.
  15. Just use a stretch kit. It will look like mine.
  16. It sounds to me like the door locks are a separate issue. I have seen multiple cases where a car would not start even with a new battery unless it was jumped or boosted in some way. The two most common reasons were bad ground connections, as stated above, or starter solenoids.
  17. Unless you put this in the wrong section the '05 up Pathys are body on frame.
  18. 3" in the front and 4" in the rear = 33's
  19. I just bought mine with 133,000. I hope those were easy. It might see 2k very hard miles a year now.
