Repack
Everything posted by Repack
  1. I was a little off in the pricing. $46 was retail price for each rod with NOTHING else. Each nut, bolt, bushing etc has its own part number. The dealership didn't have the busing kit or the bolts that anchor the rod to the LCA. I can re-use the bolts that I have. They are still in very good shape. The good news is that the guy at the parts counter seems to have given me the repair shop price. When he told me that $105 worth of parts were going to cost me $78 I didn't ask any questions! I got the arms for $34 each and the nyloc end nuts for about $3. I found the bushing kit on advanced auto part's website for $20 per side. So all told I have spent about $130 and have all parts needed either on hand or on order. FYI: If you try to order the bushings, Advanced (same as Parts America) had the bushings listed under "strut rod assembley" (or something close) so they can be a little tricky to find on the site. They were not listed with the LCA bushings. Only the fronts came up when I searched under LCA.
  2. The first dealership I called today has them: $46.85 each, including bushings. I wouldn't bother going to a junk yard. It would be like putting on a used tie rod, but even more dangerous. Unless you get lucky and find a low-mileage Pathy (is there such a thing??? Mine is at 190K) they will be too worn to be of any use. You'll snap the rod trying to get the end nut off. A friend of mine has a parts Pathy in his back yard (he's owned ~4 over the years). When I went to salvage a tension rod, it had worn down from about 1" dia down to about 3/8". It snapped while trying to remove it, which is what I expected.
  3. Wow, I'll have to check that out. $90 would be a bargain comparred to what I was bracing myself for. Thanks!
  4. The compression rod on the driver side lca of my '95 cracked (common problem). I've been told the the broken piece (a bolt on) is no longer made and that I will need to buy an entire lower control arm through the dealership. Anyone know where I might be able to find a replacement rod or two? I'm assuming that the mount on the other side is about to break. Many thanks
  5. Thanks for the info. Time to start doing some homework!
  6. All this axle talk is making me drool. The fornt of my '95 has developed a fair amount of play and I keep thinking that I should just go for the SAS. Fell free to flame me for being lazy and not looking for informaiton that I am sure is readily available all over this site, but if I wanted a D44, what is the best vehicle to pull it from? There is a very nice/large JY <1 mile form my house that has an "all you can cary for $50 sale" sometime soon and I am thinking about pulling one just to have it. Not sure how much it will weigh but even if I need to take 2 or 3 trips $100-$150 wouldn't be bad at all.
  7. Glad to hear that you are OK. Any word on the lady that caused it? Ladder frame + steel bumper = battering ram. I rear-ended a lady a few years ago in my '95. I swerved as I realized I was going to hit her so the impact was the left 1/3 of the bumper. The bumper levered off the frame rail and pushed everything back about 6" into the tire. A little bashing and I drove it home. $20 for new head and running lights at the junk yard and it passed inspection. Not bad considering that my insurance company gave me almost a grand! If I hit her square my truck would have been fine but the compact I hit would have been destroyed. A word on Insurance: I live in Mass and last year a friend had his car totalled when he was rear-ended. The insurance company offered him $3500 if he wanted to keep his car or $4500 if it was totalled. He took the $ and bought a truck. And if he had kept it he would have needed a special title showing that it had been wrecked. He never got an explanation why.
  8. It sounds like you have a refrigerant leak. The compressor will not turn on if there is not enough presure in the A/C system. But I'm afraid that your heater core may be done. I had the same problem in my '95. When I recharged the system the A/C worked like new, but after about 45 minutes the heater core would start to leak (its behind the glove compartment, along with the blower motor). The funny thing is that it would only leak on left-hand turns. I'm still not sure if the leak and the core are related. The core hasn't failed yet. I'll deal with it then. Luckily I live very close to a very large "used parts" yard. If you want to check for a leak, buy the refrigerant with the neon dye. Leaks will show up under a black light.
  9. My tweets in front are blown and I am looking for recomendations. I did a very quick search of Crutchfield and found some that started at $50. I was mainly curious about price. Any recomendations, or should I just look for some at the "used parts yard"?
  10. My dad bled the brakes on his car a few weeks ago with racing fluid and has some left over that I am thinking about putting in the disc brakes of my downhill mountain bike. What I am wondering is how long it takes for an opened bottle of fluid to draw in water. I think that I am just going to try it since bleeding them is simple but wanted to know if there was any sort of general rule of thumb or whatever. Thanks
  11. I sleep like a baby in my truck. I have a Thermarest that I wrap in a padded moving blanket to keep from getting punctured by the D-rings. A few pillows, a flanel lined sleeping bag... Not a bad place to pass out after an evening of festivities. Its like the worlds greatest dome tent. A little OT, but my friends Explorer is large enough in back to fit a full-sized mattress and the seats of the Xtera and JGC lift right out.
  12. Drill out the hinge pins and replace them with bolts and wing nuts. WIth the seats slid forward you get almost 7' of space. Makes a nice bed. The metal is very soft and easy to drill. If that is what you are talking about.
  13. I agree. I am more of an on again/off again poster b/c I (fortunately) haven't had many probloems with my truck but (unfortunately) don't have the $ to do much work to it. Not having the working email reply feature kept me away. I do not look forward to sifting through threads looking for/trying to remember what I replied to so didn't look here much while the feature was down.
  14. Repack
    Labor Day
    We aren't *that* white. The color is kind of blown. The guy in the pic has a pool that he spent most of the summer by. He's pretty dark.
  15. Thanks for the info. I knew that Bass Tubes weren't the best but didn't know that they were crap. I'm mad at myself for not thinking of mounting the amp to the box. Looks like I'll be getting a 10" most likely. I don't want it to take up too much room.
  16. I am looking to add a little thump to my stereo and was wondering what you guys thought of bass tubes. I am not looking to go crazy with my stereo. I have an Alpine head unit and the stock Clarion speakers that came in my '95 SE. I also have an amp that I can hook a sub up to but for space reasons think that a 'tube might work better. The amp I have seems too large to hids behind the panels and whatever I get would need to be easily removed when I load up with gear for the weekends. What size would you say is best?
  17. This is up near Lincoln, NH. The cement you can see is part of I-93. Very nice spot on a very nice day. There was a decent amount of people there, but we were the closest to the water. Just one more reason to love owning a truck. Thats my friend Joe, his gf on the left, my gf on the right.
  18. I test drove a 2005 a while back and was very impressed. Good chance that it will be my next vehicle. My Pathy is paid off now so I am gonna keep it but may get a gas sipper as a daily driver. The '05 X coems rated at 21mpg w/ a 265hp 6cyl and a 5speed auto or 6speed manual. You deffinatelt feel the 5th gear while driving. It is a very nice vehicle but my decision to keep the Pathy kind of complicates things. I may just end up getting the most fuel efficient vehicle that I can find that holds a lot of space. I do a lot of mountian bike racing so that would men somehting like an Accors with a trailer or maybe a CRV.
  19. That makes me happy. I hope that everyone has an excellent weekend.
  20. Wow, the email reply feature is working again! For you hole problem, would getting some flat aluminum bar work? Seems like a very cheap, simple, and effective way of putting your speakers in. Can you use the stock grills to cover them? I have an Alpine head unit and my speakers are in good shape (stock Clarion speakers). I plan to get a bass tube soon. I know its not the best, but it suits my needs. My truck has 150K on it now. B'c of the miles and the mpg it probably won't be my daily driver for much longer, but I'll never get rid of it.
  21. My Pathy was fully loaded- 3 bikes, one of which was on the roof, and all the gear needed for a bike race. Plus food. We had a lot. Top speed was 75 and that didn't happen b/c of all the hills btwn MA and WV 750 miles each way. WHen I took the Volvo a large portion of our gear was in a friends trailer. I could cruise at whatever speed I wanted and the needle wouldn't budge. The car has great sustain. Plus the last 70 miles btwn I-80 and the mountain (Snowshoe) is some of the craziest mountain driving you'll ever find. The roads are in pristine condition but turny as hell. You fo through a serries of ~2,000 elevaiton changes. Passes up aournd 4,000'. A pathy just can't compete with a Volvo on roads like that. I went from white-knuckling my Pathy to feeling driving so fast that I made my gf dizzy. I heard some motorcycle riders say that they were the best roads they'd ever ridden. I'd forgotten that the published difference btwn the 04 and 05 Xterra was only 3mpg and 70 hp. I gigure that the more powerful engine will save me money b/c it won't fight like the Pathy does. Seems like most of the driving I do involves high speeds on hilly roads!
  22. I drive ~15,000miles/year. From Mem Day-Labor Day its about 5K. As much as I hate to think about it, it seems like a AWD minivan would be the ideal vehicle for me. My Pathy is paid of and has enough miles on it that I owuld like to keep it forever so that will save me some dignity. My primary activities are downhill mtb racing, skiing, and camping. I also sleep in my truch fairly often. It sucks to think about, but a van seems to be the best overall option for me. I've also thought about getting an econocar like you have mentioned and getting a small trailer for it. Last summer really changed my perspective. I drove my mom's Volvo 850 wagon from Boston to West Virginia and back for a race. The previous summer my gf and I took my Pathy. Total fuel savings were $150+. Time saving was in the neighborhood of 2 hours each way. Its too bad that a Pathy cannot come anywhere close to matching 25mpg overall (30+ on flats, WV in incredibly mountainous) at 85mph. But all that being said, I think that my next vehicle will be a 2004 Xterra. Better mpg than an '05 with only slightly less hp. I plan on keeping the Pathy no matter what I do which will make any future decisions much easier to make.
  23. I just skimmed the previous posts so I don't know if this has been moentioned yet. My '95 did the exact same thing you mentioned. But I may have other problems. I don't know. I have never felt my ABS come on. The only time the ABS light came on it was exactly as you said- full on, then internitent. Turns out my pads were pad. Replaced them and everything was fine. Is there some function with the ABS that makes it act as a wear sensor, or does anyone think that somehting else is going on?
  24. Repack
    Quick test
    Still no worky. Just like my A/C!. But thanks for looking into it.
  25. My r tweeter blew. I'm pissed, but a friend has a parts Pathy that he said I could steel one from. Are the fronts components? I kind of thought that they were and a recent test may have confirmed that. WHen it blew I thought it mmight be a wiring problem. I hooked up a 3way 6x9 and only the tweet worked. Hmmm.
