Frenchy
Frenchy last won the day on October 7 2023
Frenchy had the most liked content!
About Frenchy
  • Birthday 03/24/1992
    1993 Nissan Pathfinder Sport
    SE Offroad
    CO
Frenchy's Achievements
NPORA Fulltime Resident (4/5)
31
  1. Understanding the concern you have, most E-Lockers you will find including the Factory E-Locker ground in the Pro-4X Frontier and Titan operate the same way. Also with a E-Locker you simply take it slow. If you become stupid and mash the throttle for no reason then yes you will see something break.
  2. As much as I would like to give a fair update, the Pathfinder was totaled last year(as of today exactly to be honest). I still have the Body Mounts that can be installed on any WD21 or D21, but I haven't been in a hurry to get rid of them. As for the shocks, I can certainly recommend Dobinsons. For the WD21 they only have the GS Twin Tubes for all four corners, but they do ride well when the vehicle is loaded up. If there is no weight, it can be a bit stiff. They also have Coil Springs and Torsion Bars available and a Steering Damper along with a complete suspension Polyurethane bushing kit. It's quality stuff from Australia and worth the money. Just be ready to pay.
  3. Yeah, those "fake" vents are not fake. They are functional and I recommend leaving them be. As for lights I used a old brush guard to mount two driving lights and two fog lights from IPF. They were awesome!
  4. The fuel gauge was simply the sending unit. It is available from Nissan. It is pricey though
  5. Chances are the transmission will be the same. The filter could be different. Chances are the fluid is Matic D. That is still available from Nissan. Personally I would just do the basic drain and fill.
  6. Best advice I can give you is to get a hold of a factory service manual. It will give you all the information you need in order to diagnose this
  7. As much as I will agree with not tightening the bolts too much, I prefer to have Allen bolts with the right size spacer. It makes it much easier to tighten to spec and when done with a basic Allen wrench you can do it by hand with no issues. I did that on a VG33E recently and I feel the results were great.
  8. Converting to manual hubs is pretty easy. I ended up buying a set of the Chinese knockoff factory hubs for a D21 of a similar year and simply took the auto hub off and put the manual hub on. Didn't even have to take the tires off
  9. Might be great opportunity to switch those to manual hubs. Then you'll know when they're engaged and when they're not engaged
  10. Should we no reason that any of the WD21 seat belts wouldn't fit.
  11. Is it going to be quite simple. First unplug your wiper motor. Go to activate it and see if it pops a fuse. If it does follow the harness and go to the next plug. Unplug it. Try to activate the rear wiper and see if it pops a fuse. If it does not you at least eliminated a lot of work of where it could be and now you know where you need to look. Of where it could be and now you know where you need to look.
  12. Unfortunately I can't really attach pictures to this form because it's special. That said if you got an eco club and open up a service manual for a '93 or even a 94 Pathfinder you can find the procedure on how to set this. You'll want to go to the engine mechanical or EM section. Everything you need should be in that. Also keep in mind that cylinder 1 is on the passenger side of the vehicle at the front of the vehicle
  13. If the fuse popped then you have a short in that circuit. Could be a wire or wiper motor
  14. There is no temp sensor that goes there. That might just be a blank hole. For the 93 Pathfinder The temp sensors sit on the coolant outlet tube that goes straight to the upper radiator hose.
  15. Do not bother with the damper. Put it on the slave and all will work out
