Tn95rbn
    Recently bought it.It's in overall great condition. Has been sitting so it'll need fresh everything. But everything works and its all original. Love it already.its a 4wd xe..i call it silver beige.y
    XE
    Lebanon,Tn
Tn95rbn's Achievements
NPORA Regular (2/5)
20
  1. Swapped out my 95 factory console for a 99 console.uca frame bolts haven't moved since they spoke japanese,but trying to get at the bushings. My camber is way off..centerlink patiently waiting.
  2. 15ish sounds fair..might be hard to find someone willing to buy knowing they have repair of the bat
  3. Theres suddenly 7/ 8 first gens either for sale or parting out relatively close..maybe Ineed a spare
    1. FirstGenFreak
      FirstGenFreak
      DO IT!!!!!!!!!!
  4. its faster to say what i havent done..uca bushings and centerlink.will be a 90% front end rebuild.but my next sunny weekend will fixthat.
  5. All the screws are ofcourse on the inside but if you can look under and up behind the handle theres a hole where the plastic pin is.The pin sits on a small spring...alittle screwdriver or tool of choice should beable to pop the spring off its little mouint without causing any damage...it just sits on a little nub of plastic on the "backside" ofthe little hole...make sure itsnot locked..should be easy enough to do...goodluck
  6. for the past month every free minute I've  had has been spent on suspension or steering...exhausting//but WOW// what a difference
  7. outer tierod end "popping" out was a bit of a let down...maybe a 1/4 inch jump out of the knuckle.However,being a first time ball joint /tierod for me Learned ALOT...
  8. one year from purchase before a mostly original XE gets the shakes..supension and steering fun ahead
  9. So 15 years later...I bought my 95 xe for 700 cash with 167k miles..couple dings and needing every bushing replaced but I think I stole it..
  10. What's up Kruppanier814 .I'm down the road in Lebanon.The members on here are as helpful and as knowledgeable a group you could hope to find.Welcome to NPORA.
  11. Appreciate the input.Think I'm going to hook up a relay and switch with a 15a inline fuse.The factory light wiring is ridiculously thin,not sure how it's lasted this long.maybe one day I'll go through and upgrade it all.
  12. True enough.Are aftermarket CV's noticibly different than what I believe are the factory originals?
  13. Cut the bumper insert and installedy jy fog light on the passenger side... (Dumb non ppe wearing me cut the crap outta my hand) Boys and girls..wear gloves!!.. Driver side tomorrow... Looks purdy if I do say so myself.PO had an alarm wired up with a switch mounted right under the little dash cubby hole to the left of steering wheel with red light mounted next to defrost switch on the dash...gonna hijack the wiring for my lights.
  14. Cut the bumper insert and installedy jy fog light on the passenger side... (Dumb non ppe wearing me cut the crap outta my hand) Boys and girls..wear gloves!!.. Driver side tomorrow... Looks purdy if I do say so myself.PO had an alarm wired up with a switch mounted right under the little dash cubby hole to the left of steering wheel with red light mounted next to defrost switch on the dash...gonna hijack the wiring for my lights.Are trans coolers directional??Also...would replacing ripped boots after cleaning and re greasing my CV joints work??..I'd like to continue using them if possible...
