Gee_Aye
Gee_Aye last won the day on June 7 2017
Gee_Aye had the most liked content!
    Just bought it! needs a little bit of work but is in great condition for its age with only 180kkm on the clock.
    Screwdriver Mechanic
    Rarely Go Off-Road
    TI
    Australia
    Australia
1,684 profile views
Gee_Aye's Achievements
  1. People always suggest using search to find the information they need but most of time the images are broken.
  2. I had to partially remove my dash to clean the AC blower because my model's dash has molded plastic that obscures the access panel for some stupid reason. I wasn't able to remove the steering wheel because of a stripped screw and so I was forced to leave it in place which has made life difficult. I'm now trying to put everything back together but it will not play nice and I am having a breakdown.
  3. Can't get my dash reassembled and I am getting very agitated..
    1. Slartibartfast
      Slartibartfast
      Dashboards are always a PITA. What part are you stuck on?
  4. I replaced the headlight wiring with a relay kit as the existing wiring had melted. Now both headlights are working and they seem to be brighter. Also removed the front door trim and factory clarions. lol: Unfortunately I was frustrated in my attempts to clean the blower and resistors. For some reason there's a big piece of molded plastic instead of a metal panel behind the glove box... perhaps a 'feature' of the right-hand drive version? I'll look at it again tomorrow, might have to cut it away or remove the dash entirely to clean out the leaves before they start a fire.
  5. Guys, I removed my glove box today to clean the blower assembly but instead of finding the metal panel with 4 screws I was confronted with molded plastic that seems to be attached to/part of the dash.... I tried to figure out how to remove the dash but have not had any success... I think i need to remove the trim that covers the demister vents so I can access the screws underneath but i'm finding it really difficult. I've popped the clips along the front edge of the demister trim but it still doesn't want to move. What am I doing wrong?
  6. Are you sure you were on the compression stroke when you found TDC?
  7. I have this problem on the '92 I just bought. Thanks for the info
