61
Everything posted by Mrelcocko
Bada$$!!!!! Sent from my SM-G530T using Tapatalk
Finally got my fog light switches. Of course my Pathfinder XE did not come with fog lights from the factory but the wiring was already there so all I done was hooked up my fog lights to the wiring stuck a relay in and changed the switch on the column and Wallah. So easy! I'm going to use these 2 switches for my light bar and reverse lights. Sent from my SM-G530T using Tapatalk
My 98 XE 2WD 5SPEED shining like no tomorrow! Sent from my SM-G530T using Tapatalk
My 98 XE with Light Bar installed Sent from my SM-G530T using Tapatalk
Love the QX4 and your backdrop is unbelievable! Sent from my SM-G530T using Tapatalk
The only part I replaced was the(center)armrest section with window controls. Added wood grain Sent from my SM-G530T using Tapatalk
Here's the passenger side Sent from my SM-G530T using Tapatalk
The door panels come completely apart. In like 3 sections. Sent from my SM-G530T using Tapatalk
the steering wheel takes a special bit to get the airbag out its a torque bit. Don't remember exactly what size but you can look in the FSM manuals and find out. You have to be careful when removing the airbag if you don't know how to do it don't, take it to someone that does. I got the steering wheel out of a 99 maxima. You have to make sure the holes line up behind the airbag in order for it to work you will see what I'm talking about if you ever take it apart. Also the cruise control buttons the way they mount on sometimes don't work right either you have to make sure all that is right. I found the steering wheel I wanted but when I went to put it on the cruise control wires didn't match up. The amount of wires can be different. Sent from my SM-G530T using Tapatalk
98 XE 2WD 5SPEED Sent from my SM-G530T using Tapatalk
Sent from my SM-G530T using Tapatalk 98 XE 2WD 5 SPEED
My 98 XE with door panels off a 2001. Easy upgrades. Also when changing panels you have to change window and lock switches plus wiring depending on what model your upgrading. Sent from my SM-G530T using Tapatalk
I also installed a dual USB charging port and Light Bar. Along with adding wood grain throughout plus upgrading steering wheel Sent from my SM-G530T using Tapatalk
Gauge cluster along with A/C climate controls and so on. Sent from my SM-G530T using Tapatalk
Cruise control and dimmer switch. Sent from my SM-G530T using Tapatalk
Awesome Pics! Sent from my SM-G530T using Tapatalk
Install LED lights throughout the interior of my 98 Pathy XE. The cluster and switches. Added dumby switches for my enjoyment. Almost every switch lights up and most of the time they burn out on their own and I think it's caused by the little rubber thing they put over it to change the color that the bulb puts out. Any questions on how to do any of these things don't hesitate to ask I can definitely show you step by step on how to do it. Sent from my SM-G530T using Tapatalk
Thank you Sent from my SM-G530T using Tapatalk
Very easy to adjust the TPS. All you need is a volt meter and a know how. FSM manuals are so helpful. Any questions feel free to ask. Sent from my SM-G530T using TapatalkTPS sensor was toast! Put a used one on wallah! FIXED!I overlooked it in the fsm. It does say it. Thanks guys!I dont have a rear LSD on my 98 Pathy. Its a 5 speed manual and I was wanting to know what kind of oil I need to use. It doesnt say in the FSM what kind of oil i need to use for a non REAR LSD DIFF. Please help!
- Create New...
