Everything posted by maddmark1981
Yes I do have this problem
Sounds like you shook something loose. A ground possibly. Id start there by looking it all over. Have you been boosting much or charging the battery while both + & - are still connected?
I swapped both fuses in the interior fuse box 15A and theyre fine. Still no blower.
Hey guys Im hoping that someone else besides myself has had this issue and know where the problem is. A few months ago my power locks started locking and un locking at random times and also my power windows would make a clicking noise in the passenger door. Id hit the door and they would work. Then one day they both stopped working. I replaced the fusible links on the battery, cleaned up all the ground wires i could find, cleaned the master switch. I tried looking at the shop manuals on here but still nothing makes any sense. Please help. Thanks
Awesome. Thank you
I seen this was broke off but dont know from where can someone help. Drivers side below brake fluid resivour and a little towards the front grill
Also just checked the fusible links i replaced with the meter, they look fine
Ok so I cleaned the master switch throughly and still nothing
Im terrible. Im on tapatalk and it wont let me open the service manual. Does anyone know if theres a fuse? Im cleaning the master switch as we speak with EC Cleaner..
I will check the master switch. But i suspect a deeper issue. I replaced the fusable links and soldered them. Im guessing its a fuse that dont seem to exist Sent from my LG-H812 using Tapatalk
Nobody seems to know the solution. They must be fused somewheres. I cant find any fuses for the power windows, locks and hatch glass popper. I have power in mirrors and wipers but my heater/ac blower isnt working either they all quit at once. I replaced fusible links already Sent from my LG-H812 using Tapatalk
I dont have a service manual. But i got my door open. Now i just need to figure out where to look for the power window,locks and hatch glass Sent from my LG-H812 using Tapatalk
Is there a fuse for windows, locks and trunk glass popper button? Sent from my LG-H812 using Tapatalk
Some time ago I noticed my windows were acting up when i would push the power window button sometimes it would not roll and id hear a clicking noise on the passenger side. Then the power locks started acting up locking and unlocking on their own while driving or id get out after shutting it off and they would randomly lock. I locked my keys in once. But then ka put they stopped working all together both the power windows and locks. Now i cant get my passenger door open. Any suggestions. Thanks in advance Mark Sent from my LG-H812 using Tapatalk
Sorry to hear. Sent from my LG-H812 using Tapatalk
Thanks a lot buddy, much appreciated Sent from my LG-H812 using Tapatalk
How can I haywire the locks? Sent from my LG-H812 using Tapatalk
But keep in mind the power windows, locks went just before the charging issue Sent from my LG-H812 using Tapatalk
Yes I just repaired that and checked the FL on the multimeter all good now Sent from my LG-H812 using Tapatalk
When I put the washed out alternator back in it wasn't dry or something moved inside when I was hitting it with the air compressor. When I plugged the alternator into the harness located in pic. Under air filter the wire which was green now replaced with heavier red wire and black taped caught a fire. The alternator also was smoking intensely. After replacing both wires taped I got stereo, wipers, mirrors, but still no windows, locks or blower motor for heater & a/c Sent from my LG-H812 using Tapatalk
Ok so I did that and replaced one but still no blower motor or power windows and locks Sent from my LG-H812 using Tapatalk
No I have not. Sent from my LG-H812 using Tapatalk
Ok so you were right there was a wire that had melted. I got everything back except the power windows and locks. I'm trying to figure out for the life of me how to get my passenger door open. Or the window. Sent from my LG-H812 using Tapatalk
Could someone point me to the wiring diagram? Sent from my LG-H812 using Tapatalk
I'm trying to trace where there might be a fuse or cooked wire, stereo is dead too so all electronics are not working at all Sent from my LG-H812 using Tapatalk
