Everything posted by DanF.
Thanks. I was starting to lose my mind.
How did you access the Nissan Pathfinder lift on their site? I can't seem to find it except by clicking your link. I have an Xterra as well as my wife's Pathfinder, and am curious if they offer a kit for that.
It doesn't seem to be as far back as the transfer case/driveshaft connection. It's in the same exact area as the 4wd sensor location that was a leaking issue before.
Yeah, the drip pattern is only on the passenger side. It's as if it's being sprayed up at the body of the truck, and traveling down the "frame rails" and dripping further out towards the doors/step-bars. I'll be moving to rental house soon, and it has a small garage. I'll be able to jack the Pathfinder up and take a peak at the problem and try to find the issue. Right now our apt. parking lots are all angled, and covered in snow/ice. It's also too f$#king cold out to bother trying.
OK, thanks for the suggestions guys. Where are the lines located on the transmission? I've got a ton of snow outside now, and am going to have to wait until there's a bit of better weather to do any investigation.
2004 Pathfinder 3.5 4x4 Automatic There is a sizable leak that coming from somewhere not visible on the bottom of the transmission/transfer case itself. It is as if there is a pressurized leak spraying up and over to the passenger side, between the two doors. It is coating the underside of the Pathfinder, but not actually leaking down from the transmission. It's getting difficult to figure this out. Several months ago my wife brought it to her mechanic who said that the 4WD sensor was leaking. After replacing that sensor with a new part the leak seemed to go away, until a couple weeks ago, and now the leak is happening fast enough where it's causing issues with how the transmission operates. It is currently spraying out onto the bottom of the passenger side in the same place as before, and causing the same drip pattern on the ground when the Pathfinder is parked. I don't normally drive the Pathfinder (wife's rig) and have to rely on her description of the issue. She finally admitted that it was shifting weird and stalling out at STOP signs. I drove it yesterday, and while checking the fluid level found it was not even registering on the dip stick. Awesome. Once I filled it up with Dexron III ATF the transmission shifted normally and operated as if there was no issue at all. So that's nice. Her mechanic swears that he can't find the source of the leak, and I'm not too fond of his lack of ability since he seemed to have no problem finding the previous leak. He claims that sometimes the transmission just runs low after a lot of driving. WTF?!? So, my question is: Where are the possible places where the transmission could be leaking from?
D21/Hardbody wheel compatibility with WD22 Xterra
DanF. replied to DanF.'s topic in 90-95 WD21 Pathfinders
Ok, thanks. I know the wheel will mount the hub just fine. I was wondering more about the offset and backspacing issues, but after reading some more info/specs. I was able to find out that there'd be some rubbing issues. -
Edit: I posted this question on clubxterra.org, but haven't gotten any replies. I found a craigslist ad with Nissan wheels and year old winter tires for cheap, and am wondering if they will fit my 2004 Xterra without rubbing. I know the centerbore and lug pattern are the same for the two vehicles, but I'm wondering if any of you guys know about whether the offset and backspacing would be an issue. My Xterra is stock. The seller messaged me back saying that the wheels are off of a "mid-90s Nissan truck". I'm guessing he is referring to a D21 Hardbody. Here is the ad: https://nh.craigslist.org/wto/5936221805.html TIA
Is the R50 manual gearbox the same one that is in the WD22 Xterra? I know the automatic transmissions are the same JATCO units.
Is there a write-up anywhere with pics. on this forum? My wife's '04 SE 4x4 is starting to leak PS fluid and the shop wants $700+ for the rack before labor is added.
R50 performance upgrades. What all do you have done?
DanF. replied to haydenmidd12's topic in 96-2004 R50 Pathfinders
I threw a reusable, synthetic dry-element, air filter into my 3.5L R50. Added at least a 2%* increase in power. http://www.upgr8.com/store/oem-replacement-panel-air-filters.html?make=88&model=554&year=61 The 3.3L and 3.5L are (dimensionally) identical as far as I can tell. I got the red one on Amazon because Prime > anything else, and I don't see any info on why the green version is $10 more. *might be more like .02% -
3.5L air filter question - Has anyone used this one?
DanF. replied to DanF.'s topic in 96-2004 R50 Pathfinders
Short-term update: Filter arrived three days ago in perfect condition. Nice packaging, and came with two decals/stickers; one to throw up on your window, and one to affix to your airbox with date/milage info. I didn't whip out a tape measure and compare dimensions to the 0.0001", but my calibrated eyeball didn't see any variation from the stock paper filter. It fit into the filter holder, and dropped down into the airbox easily. It was the smallest bit snug, but I was able to get it clipped into place with no problems. Driving: The old filter was at least a year old, and was dirty. Car seemed to be getting more sluggish, so my butt-dyno perceived a small improvement in top-end acceleration, but I assume this is a placebo effect, or simply because a new filter will flow better than a dirty filter. Anyways... it's a filter, so it's not that exciting. If it lasts for a couple years, and allows me to easily clean it, I'll have gotten my money's worth. Not the worst thing to spend $20 on. -
Yeah, there were one or two others that I was also going to buy, but noticed that they were pre-oiled. No good. It was either this filter, or one of the others... AEM perhaps, that had some reviews saying the rubber surround was dimensionally off by a few millimeters, and that it was necessary to trip some of it. Either way, I'm not worried about it as long as it's close. I care about a good seal and air flow vs. filtering/protection. I should get it in a few days, and I'll take some pics. -
What is the benefit of running HD springs up front and MD in the rear? Are you guys dealing with a lot of extra weight mounted up front (aftermarket bumper, winch, etc...) or is there a handling benefit?
DanF. posted a topic in 96-2004 R50 Pathfinders
Upgr8 U8701-3001 Hd PRO OEM Replacement High Performance Dry Drop-in Panel Air Filter https://smile.amazon.com/dp/B00LNOY5WG/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=1Q57SEEA9S0XO&coliid=ILMG2S5WZGUAK&psc=1 It's more than a stock filter, but it's reusable and should pay for itself if it holds up for a year or so. -
Monoprice has been around for a long time in the electronics arena. They seem to be branching out into other departments. I imagine they get their Monoprice branded products from the same overseas factories that big-brand companies use. Previous to seeing the Monoprice coolers, RTIC (former Yeti employees) had been the best value. I think it's insane that companies charge the $$$ that they do for essentially the same products.
false belief
https://www.monoprice.com/product?p_id=15638 I just saw these on their site, and it looks like they are expanding their outdoor products range. Could be a great alternative to an Abominable Snowman® or other overpriced coolers. It would be great to hear if anyone has any experience with them.
Biscuits.
Gun Bunny
Thanks for the reply. Rear springs seem to sag a lot over the years on these R50s. I know mine are really sagging.
Was that the AC 2" lift?
Anyone crammed 35s in with a 6" lift?
DanF. replied to Snowboarder12345's topic in 96-2004 R50 Pathfinders
It's not moderated, so there's lots of dumb stuff: same lift questions posted 3 times a day, help... my engine won't work, should I run LED lightbars during the day, etc.
