Everything posted by ryan88pathy
Sweet. I'm sure we all would be willing to sit through a how to for it. I have some good ?'S to ask. Sent from my SAMSUNG-SM-G900A using Tapatalk
Ya I changed the oil in it with added additive and I do think it's broken. I just really want to know what I'm getting into before I dig myself a whole. Sent from my SAMSUNG-SM-G900A using Tapatalk
All I can say or believe that the previous owner of my 96 messed with the lsd to tighten the clutches And now it whines,clanks,pops and makes all kind of noise. Try pulling a tight 360 and the tires churpe like baby bird and not in the good way. It's actually is binds so hard it sounds like it's going to break. If you do decide to open it up please video it. Many here would like to see it taken apart. Sent from my SAMSUNG-SM-G900A using Tapatalk
Man must be nice. My wife flips anytime I spend money on my pathy. And the Texas flair is a good thing. Just waiting to do my front bumper when the heat lowers a little. It should be the best thing in DFW. Sent from my SAMSUNG-SM-G900A using Tapatalk
00 pathfinder needs CV axles for the 4x4
ryan88pathy replied to fearkobe's topic in 96-2004 R50 Pathfinders
I'm sure he has the electronic 4x4 switch and not the manual. So manual hubs would be bad. Sent from my SAMSUNG-SM-G900A using Tapatalk -
Energy Suspension bushing sleeves too long?
ryan88pathy replied to unit6usa's topic in 90-95 WD21 Pathfinders
Mine fit with a little work but work great. I think the price alone is worth buying the energy suspension bushings. Sent from my SAMSUNG-SM-G900A using Tapatalk -
Sweet ride and good pics. Welcome!
I think most of us have all done these rear bushing but just an idea for any one else out there who might need a crude way of extracting the old ones. After removing the rear arms most people tend to press out the center sleeve, I tend to burn them out with a small propane torch to get high off the smell and kill a little more of our ozone. Once the sleeve is out I go to a trusted ball joint fork and a BFH (big f@cking hamer). I start on the lip of the pressed fit bushing with the fork using it as a chisel. Then turn it over and repeat. After going to town on the old bushing it should just fall out. I would not recommend doing this if your going back to using the OEM press fit bushings as there will be a little scoring from the chisel work and would probably cause some binding when trying to PRESS the new ones. I went with poly bushings so there was no issue. For the next trick I will install the upper bushings with oem press fit ones with out a press. This should be fun!
Gl-5 80w-90 I do have to say and repeat. Inspect the one your going to swap and make sure they have the right gear set. I to am looking for a new one for my 96 with the lsd with the 4.6? And it's a PITA.
I've done the driver side lower and after 3 hours of wanting to commit suicide I hade it finally back under the car just to find out the axle had moved back 4 inches. It wasn't that hard to get it back into place, it just took me breaking 2 ratchet straps and saying a few Hail Marries. Now for Friday to get here to do the other side. Forcast says 100% of rain. Ya sounds like my life is on track! I'm going to try and take pictures to show yall how southern rednecks fix things. I wonder if McGiver was from down south. He could rig everything to explode.
Replaced rear drivers side trailing arm bushings. What a PITA.
Yes it should, and I did know one idiot who had an H. accord and thought it was a Jeep back in high school. For anyone who knows what these are. I had received my rear bushings oem style last week and mulled over the thought of how week they look and after many hours of killing brain cells thanks to many PBR'S I set out looking for poly bushings. Come to find out only ebay and 4x4parts have them AND 4x4parts didn't have enough. After measuring and searching I think I came across the right ones from aftermarketenerysyspensionparts.com, part # 9.9485 Flange Type Bushing $20.76 and it's 2 bushings to a set, that's $10.38 a bushing, sure as hell beats $25.00 a piece at the autoparts store. Lets hope they fit when I find the time to install them, Two jobs really kill the mood.
WE NEED MORE FLEX! I'M GIVINHER ALL SHE GOT CAPTAIN!!!
I love the color, and it's pretty sweet looking to. What color of plastidip did you use and and how well is it holding up?
Can't wait for the how to! SWEET.
Update. After driving for a few days a and about 200 miles the pathy has been a rockstar but have come accross a few more things that need to be fixed. Rear bushings are shot and have arived in the mail just yesterday with few extra parts after it taking all week. The wait just kills me. THe big issue that has come up is a noise from the rear end that sounds like a tire is rubbing a fender when im in reverse and is realy bad when turning in reverse. My guess is it's the LSD and (1. has no oil) (2. it has the wrong oil), or (3. its about to go out).
engine problem, sudden lost of power P0011, P0021
ryan88pathy replied to maikan's topic in The Garage
Clogged cats maybe? A good sign for that is low power, no acceleration, backfires and I think rapid oil consumption at least it did in a Geo we had. I would run the car for 30 minutes and see if the cat is glowing red or disconnect it to see if all comes back. It's worth a shot but will be loud. -
vibration from duratracs or ome springs?
ryan88pathy replied to 94svt50's topic in 96-2004 R50 Pathfinders
I'm wondering if it isn't something easy like a warped brake rotor but I also think the cv's aren't helping. Mine has a bad shake when stopping and just a little at highway speeds. Going to replace front bushings to see if it helps, then rotors, and if it doesn't stop I'll buy some manual hubs. I think Just about everyone has some kind of issue like this. -
I got around to changing the spark plugs yesterday and found the cylinder #5 misfire was due to a bad plug. There was a good bit of the oil sitting on top plug when I pulled the wire and after pulling the plug found it to be burnt. I'm hoping this is nothing and not a bad valve guide or something small like leaky head gasket and it was a bad plug from the start. I'll give it a few days and look at it again and evaluate if theres a larger problem. I do have to say after replacing the autolite plugs for NKG it is amazing how well this thing runs. I hope most of the codes clear! Now I'm waiting for bushings to come in the mail!
Nope no light. That was a fun surprise! As for the injectors I'm hopping that there just clogged and won't have to buy them but there are a few at the local junk yard. O2 sensor. ... Down stream passage side? Well if there's one past the cat or should be one ...... well there isn't . But I did find there's magna flow exaust on the car. I'll definitely down load the manual. Thanks and will update when I get some time to work on it hopefully this week.
I went to get it inspected and had 3 codes pop up, cranks sensor, misfire cylinder 5, ( 02 sensor (bank 1,sensor 2)) any help would be great. Plan on changing all ignition stuff, wires, plugs, rotor, cap, and cleaning injectors to try and get the codes to clear.. Also on the list are rear link bushings (there shot), fixing the check engine light since it doesn't work, timing belt and other accessories that go with it and the newly found rear break leak. The front end shakes a little at highway speed and a lot on breaking so i'm thinking either turning the rotors or just buying new ones. Looks like im going to be broke before to long. This morning I finished sticking the new tires and rims on and does it look good, ill take pictures when it stops raining. Any advice from the crowd would be nice.
Sounds like they won't be but at least you can have the satisfaction that there done right and you still have your arm and leg. Can't wait to do mine.
all from Craigslist $900 pathfinder $400 rock rims and goodyear tires $100 2'' spacers
and it wont let me post pics
Hello All, Srarting out I have been a member for a short time but a reader for a long time, Thank you to all for helping with your addvice and expertise for all of us newbies. I have been a proud owner of a 88 pathy for a few years now and have enjoyed every minute of it through the good and bad times. Just ths past year my family was blessed with baby girl bringing us to family of four. With all new things something must be put by the wayside and it just so happened to be the pathy. Not to make this a long post if you want to read more into the last year dealing with the 88 feel free to read the new members post (HELLO FROM TEXAS). The wife had made a comment when trying to get the kids in the back seat with a few choise words that im not going to repeat but the bottom line was it was just to hard to get the kids in and out. With her advice and consent I started looking for a new pathfinder that would take the place of our once loved 88 pathy. After looking for two months I came across the right r50 that a young man recieved as a hand me down from his grandparents who bought it new in 96. When it was perchaced the pathy spent most of it's life behind the back of a RV being towed across the country for an easy put put car to get around in. She had spent 12 years being towed befor the couple decided to hang up the rv keys and retire for at home. It wasn't till 2005 when young man received it from his grandparent as a high school graduation present and was in his care till I perchaced it from him. Now to the good stuff. I found the car on craigslist for $1200 obo with 190,000 miles and said it needed some work. After a hour trip to look at it I knew it was the right car for our growing family. spec. 1996 pathfinder 5 speed, 4x4, electric windowes, locks, sunroof, spare tire swing, clean interior, and new radio. The bad, both front cv axles are bad, swaybar links, old tires, sun faded paint, a few minnor rust spots on the body, rusty bumpers, rotted nurf bars, and broken antena. So far over the past week I have started to replace both axles, new swaybar links not installed just yet for front and back, and I just scored 2" spacers off craigslist for $100. I'm also looking at black rock crawler rims 15x8 with 31,10.5 wranglers on craigslist for $400. Does anybody have any extra things that I should be looking for out side the norm that yall have come across that a newbie might not know about and any after market things that i should get to extend it's life ? I will try and load pictures in the next few days.
