7
RCWD21 last won the day on June 4 2020
RCWD21 had the most liked content!
About RCWD21
- Birthday 12/22/1993
Rebuilt 2 door, tons of parts, almost finished with it. Or so I keep telling myself
Skilled/Experienced Mechanic
1987
Gender
North Carolina
Country
4,187 profile views
RCWD21's Achievements
NPORA Old-Timer (5/5)
151
RCWD21 started following Wd21 flashing battery light with key on engine off
As a super late update on this I got new injectors from a different company that rebuilds only oem cores here in the states. It runs much better now, albeit I have a random high idle so I still need to deal with the tps. As for the flashing battery light before starting, it rarely does it now but I still haven't figured out what's wrong or causing it. I've swapped relays around and can't find anything concrete. Sent from my SM-G998U using Tapatalk
The 26 psi is the spec for that vehicle. The 44 psi is the max pressure at the max rated load for those tires. Stick close to 26 psi and you'll be just fine. If you feel 26 is a bit too soft then you can bump the pressure up a few psi and see how it does. But be sure to check your tire tread wear pattern to make sure you're getting even wear across the face of the tread.
I have 6 remaned injectors coming in from rockauto hopefully Monday that I'm going to install and hopefully it'll solve all of my issues. At this point everything but the TPS and ECU will have been swapped. My crappy Chinese injectors were too rich, these used oem ones seem to be lean, and hopefully the rockauto ones will be right on the money lol
Its gotten so bad on there. And I'll try a link to my post and I have another video I took this morning of how the vg33 injectors are doing. Fb link: https://m.facebook.com/groups/NPORA/permalink/10160270193930129/?mibextid=Nif5oz Here's a link to the vid from this morning. To add to things, there's no dark smoke or smell of flooding with fuel. Just a touch rich from the engine being cold still. https://www.dropbox.com/scl/fi/fwsawa9etzw9zcgdddj2y/20230814_091321.mp4?rlkey=pwg3zgcgyribpy2b17wf9bwry&dl=0
The light flashes about the same speed as the turn signals do maybe a touch slower. I have a video of it but obviously can't post it on here. The donor vehicle was a 91 and I've been through the entire harness adding in intermittent wipers and cruise control and removing ABS and the rear door wiring. I never modified the engine side of the harness except for the vg33 injector connectors. I did post the vid in the NPORA group on fb though. As for the injectors I replaced one with another seemingly new injector I had found in a u pull it yard. It appears to be OEM as well luckily and it runs a bit better and I can even reach the rev limiter for the first time since I bought the rig back in 2015.
Wiring checks good and no its got a 125 amp alternator from a quest installed since I run a winch and lights, etc. I do suspect that it may be a flaky relay on the inner passenger side fender (that tiny 3 pin one) the mpfi donor had 310k on it so there was definitely lots of use on everything. I've unfortunately had to sideline this issue as I'm chasing my tail trying to resolve a misfire that comes and goes below 3500rpm. I've swapped everything except the ECU, TPS, O2 sensor, and Igniter chip. It also dropped to 5 cylinders on me on my way to our shop today so I need to make sure an injector hasn't quit on me. I got some oem used ones from a vg33 so I could have the newer connector after fighting with cheap ebay ones that were just way too big on fuel delivery.
Just recently did a mpfi swap on my 87 and everything has been fine until I swapped to some different injectors. After that amd at random (2 or 3 times so far) when I turn my key on the battery light will flash and the small 3 pin main relay under the hood on the passenger fender will click in unison with it. I can start the engine normally and everything works still its just the relay clicking and battery light flashing that worry me. Sent from my SM-G998U using Tapatalk
Just do a regular oil change, there's no need to stress over the tiny amount of oil left in the pan after draining the oil
Well, I've already converted the 91s dash harness to feed the 87 cluster (I really like it and the 91 cluster was really sun faded and the speedo needle us crispy curly). I've made up a little breakout harness to feed the TBI tach directly off the cluster and BOTH my TBI tachs dont respond sadly. Do you think they're dead from powering them via the MPFI wiring coming from the ECU? Everything else in the cluster works and I can even plug in the 91 tach and it works. Unfortunately the tachs themselves are completely different design wise being that one is back lit and the other is the crappy front lit needle. Also the spacing and center hole for the face plate is slightly different. Sent from my SM-G965U using Tapatalk
RCWD21 started following 90-95 WD21 Pathfinders
I just got done swapping my 87 over to mpfi (was a 91 donor) and need some help with the tach from the TBI setup not working. The MPFI tach works just fine when plugged in. Are the signals different between the TBI and MPFI? I have 2 clusters from TBI models and neither of them will work. Only the original MPFI tach will work. I've seen that the wire that would normally go directly to the tach on the TBI setup goes over to the MPFI ECU and then over to the tach. Its pin 2 and 3 on the ECU and when testing with a multimeter I dont get continuity across those pins. Sent from my SM-G965U using Tapatalk
RCWD21 started following Urgent Tachometer help needed
Yea, the rubber was so bad the inner sections popped right out. And here's a link: https://www.ebay.com/itm/172769763848 Sent from my SM-G965U using Tapatalk
That would be mine then, and its actually very thick tubing meant for fuel, oil, and engine bay type temps. It doesn't even collapse under full vacuum from a vacuum pump unless its heated to the point of it being malleable. Sent from my SM-G965U using Tapatalk
Are you talking about on mine or the OP's? Sent from my SM-G965U using Tapatalk
Is the area you're going to be running in hilly, bumpy, or otherwise steep? A carb off road even with antislosh kits in my experience are no where near as good as tbi or mpfi. Better fueling, no flooding, starts faster and runs cleaner. Not to mention if you ever roll it you wont have gas pouring everywhere all over everything. I'd personally get it running right and run it with the tbi system, you'd be surprised how torquey it is and how good it runs when you really need it. Sent from my SM-G965U using Tapatalk
That's what mine started doing you could dump the clutch from an idle and the axle would shift a good inch or so. Do you think it would be a good idea to replace the panhard bar bushings as well? It's just those 2 spots and every single bushing will have been replaced lol Sent from my SM-G965U using Tapatalk
