whatchugot12
About whatchugot12
- Birthday 05/11/1997
I have a 1997 & 1999 2wd Pathfinders.
Screwdriver Mechanic
36-40
Rarely Go Off-Road
XE
1997
Contact Methods
Yahoo
from_nothing2words
Gender
Nashville, Tennessee
Country
Interests
Party time=Excellent....roflol...seriously though: I like tips and tricks on cars(Pathfinders), life hacks, and how to videos.
1,863 profile views
whatchugot12's Achievements
Had similar issue with my 2001 Nissan Pathfinder SE 4x4 5spd after I had changed everything in the front end out and put a small lift on. Though I thought like you probably (wtf); I later discovered that it just had to settle a bit. Then I had some creaking popping noise too about 30,000 miles later and got worried about it and took to the Facebook 96-04 R50 page. They were pretty dead on with guessing a cv axle either going out early or like my mechanic told me; "it might have just got in a bind" as I was unable to replicate it. Hope this helps. Good luck and I'd encourage you to check that Facebook page out! Sent from my SAMSUNG-SM-G900A using Tapatalk
Help: 97 Pathfinder - Single or Double Din?
whatchugot12 replied to joserabagojr's topic in 96-2004 R50 Pathfinders
Double din! Sent from my SAMSUNG-SM-G900A using Tapatalk -
Hey all! Got a bit of hesitation with my truck upon start up and was wondering if anyone has any ideas on what I should or could do? I have done all the main stuff within the past 6-9 months. NGK Platinum plugs, fuel filter, air filter, new muffler, and fresh oil changes as needed. My tires are 265/70 r16 General AT2'S so I understand that my mileage for gas might be decreased by a little bit but since the new muffler 2 weeks ago it's even worse. I'm getting about 14.5-15.75 mpgs and thought with the new muffler I'd be possibly increasing my mpgs. Anyhow, I saw on the 96-04 R50 Facebook page that someone had changed their MAF sensor and that it now runs like new. Keep in mind that my Pathfinder has been pretty well kept and maintained so I'm leaning towards purchasing a new one (MAF sensor) just to see what happens. I'm no mechanic though and would appreciate any information or advice for doing this swap.Thanks in advance! Sent from my SAMSUNG-SM-G900A using Tapatalk
Hey all! Got a bit of hesitation with my truck upon start up and was wondering if anyone has any ideas on what I should or could do? I have done all the main stuff within the past 6-9 months. NGK Platinum plugs, fuel filter, air filter, new muffler, and fresh oil changes as needed. My tires are 265/70 r16 General AT2'S so I understand that my mileage for gas might be decreased by a little bit but since the new muffler 2 weeks ago it's even worse. I'm getting about 14.5-15.75 mpgs and thought with the new muffler I'd be possibly increasing my mpgs. Anyhow, I saw on the 96-04 R50 Facebook page that someone had changed their MAF sensor and that it now runs like new. Keep in mind that my Pathfinder has been pretty well kept and maintained so I'm leaning towards purchasing a new one (MAF sensor) just to see what happens. I'm no mechanic though and would appreciate any information or advice for doing this swap. Picture of my truck below. Thanks in advance! Sent from my SAMSUNG-SM-G900A using Tapatalk
VQ35 excess oil consumption - Is it terminal?
whatchugot12 replied to Martinjmpr's topic in 96-2004 R50 Pathfinders
Oil cooler on the VQ35 manual transmissions??? Thought that was only the automatic versions. Sent from my SAMSUNG-SM-G900A using Tapatalk -
Anybody know where to get the "blend door cable"? For a manual controled heat and air control panel????? Sent from my SAMSUNG-SM-G900A using Tapatalk
Try blowing out the vacuum lines and charcoal filter. That was my problem with the 97' model Pathfinder I had. Sent from my SAMSUNG-SM-G900A using Tapatalk
Thanks..I'll look for your write up on this subject! Sent from my SAMSUNG-SM-G900A using Tapatalk
Help! Can't figure out my blend door problem!
whatchugot12 replied to whatchugot12's topic in 96-2004 R50 Pathfinders
Any link to the 2001 FSM? Sent from my SAMSUNG-SM-G900A using Tapatalk -
Any chance of getting a video or some type of visual instruction for repair? I'd really appreciate it. Sent from my SAMSUNG-SM-G900A using Tapatalk -
Help with my blend door problem! 2001 Nissan Pathfinder SE 3.5L 5spd and 4x4 with manual heat and air control panel. Advice please on a broken blend door! Sent from my SAMSUNG-SM-G900A using Tapatalk
whatchugot12 posted a topic in 96-2004 R50 Pathfinders
Can't understand why my blend door is stuck with the vents on "face". This time of year I had the heat on and when I changed to defrost while on a high setting it "broke" and is stuck on face. Any videos or suggestions for the repair would be greatly appreciated! BTW, it's a 2001 Pathfinder SE 3.5L 4x4 5spd manual if that helps along with manual heat and air control panel. Thanks!!! Sent from my SAMSUNG-SM-G900A using Tapatalk -
whatchugot12 started following Parts For Sale , Vehicles For Sale , Trail Run/Events and 5 others
