green180
Everything posted by green180
  1. Once I get my struts and shocks on I'll be heading down to gorman, looks like fun
  2. Thanks bc, I have a.c. lift springs in front, and wj cherokee springs in the rear with spring mounts I made, cool, I'm located in porterville
  3. What part of central California are you from
  4. Awesome, thanks for the heads up I need them
  5. Hunting trip, gave the pathy excessive Arizona pinstripping thru quad trails
  6. Any pictures of what you ordered?
  7. You weren't kidding when you said ours look the same, I want to see some side shots of your truck, have you installed a lift yet
  8. Hey dustinp what are the dimensions of the spacer under the blue spring cup, I need to build a 2 inch spacer for mine, I have jgc springs in the rear already on my r50, thanks
  9. No just window sealant and bolts, I haven't heard any noises yet and it's still sturdy, we'll see once I take it off road with all the flexing
  10. No just window sealant and bolts, I haven't heard any noises yet and it's still sturdy, we'll see once I take it off road with all the flexing
  11. That would be awesome I've been wondering what's back there, please do
  12. Thanks nefarious, eventually ill install lock washers, the 2 inside nuts are welded on, on both brackets, it's tough to get my hands in there so I did that instead
  13. Haha thanks bushnut, I did, I ended up using window sealer silicone in between the carrier and body, same with the latches
  14. Thank you, I made those plates as close as I could to the shape of the quarter panel, I'm thinking of attaching both plates I'm just waiting on more time I would've liked to hole saw a hole in the second layer of the c pillar and weld a pipe to both layers for more strength, I worry that over time the panel will crack around my plates
  15. I put my weight on it with it open and it didn't sag, I want to add more bracing though before I add a tire and gas can
  16. A friend and I installed the carrier I had sitting in my garage, it's off a 1997 but it fit perfect, I'm looking for ideas to reinforce it more
  17. Let us know what happens, if worse comes to worse ill buy your lift setup
  18. I'm a mechanic and I started out with a small box of husky tools which I recommend being that I still have and use the ratchets and sockets even after hammering on them, I bought them 7 years ago, I've had good luck with harbor freight impact sockets, the majority of my air tools are matco, and the rest of my tools are snap on, I wouldn't cheap out on air, electric, or torque tools since you want those to last and be accurate, also you don't want an air compressor inside unless you want your hearing to go
  19. Sound like your egr isn't doing its job
