Everything posted by 93_ditchfindah
cb radio install location!
93_ditchfindah replied to 93_ditchfindah's topic in 90-95 WD21 Pathfinders
nope but i have the link from cobra whrre i bought it from above precise1 hahaha^^ -
so your running 1" ball joint spacers on stock ucas? how are the ball joint spacers? people have mixed deelings about em and where did you get em?
well... after thinking it through... haha battery is hopefully not junk!! new hampshire was 3 degrees away from a record set 146 years ago at -10 two nights ago. and i havent even staryed my truck in about 3 days haha. can you say FROZEN BATTERY???!!! brought the battery inside so hopefully its good to go by the mornin haha -
well i just got done putting mine in to test her out! and after i got it all working i found out the battery was dead! i jumped it and let it run for 40 minutes.... shut it off and went to start it again..... dead again... i cant win! -
im sorry if thouse arent what you were looking for but thats all i have for pictures! if you really need something specific i could probably take the dash back apart for you to snap a pic.
could you post a picture of how yours is set up? (how it looks between the seat) -
this is exactly what i had tried doing but was afraid if i shaved down the radio brackets the cb radio would be loose and shake around on the trails? should i just go for it or.... -
Hey everyone! Just got a Cobra cb radio with a pa speaker!! was wondering where you guys have your radios mounted? i have a 93 pathfinder with the round dash conversion! i tried putting it below the radio in the center of the dash... but was barely too wide!!:/so 94 and up dash locations please! thanks in advance ill upload pic if needed too! heres the cb radio http://www.truckers-store.com/store-products-c148gtl-Cobra-148-GTL-Classic-SSB-CB-Radio_39990947.html (not the smaller one it a lil bit larger thand an aftermarket radio
when you look on youtube to see how different exhaust sound on your truck(everyone knows a chevy with a flowmaster on it).
sorry for such a late reply! but your radio will actually ground from the antenna input. when you plug in your radio intenna it actually ground the whole radio but i assume you already fixed your problem! hope you got it working!
since you recieved the 4.5" of lift in the rear what did you do to the front to make even?
2nd Chance - February 2014 TotM Nominations
93_ditchfindah replied to RedPath88's topic in Truck of the Month
what part of the rules did i mess up? ive been a member for 5 months and have over 100 post and the trucks in the snow theme... -
*Read the Rules* -
are you looking for the pre 94 right side or 94 and up?
are you getting the 3.5-4" with the 1" ball joint spacers included in the front? and if you were getting 4" in the front ive got two questions? 1: Hows your downward travel? 2: Do you have coil spacers in the rear to make the truck sit level?
1995 pathfinder to 1999 pathfinder
93_ditchfindah replied to LOVELADY's topic in 90-95 WD21 Pathfinders
what about ecu all the same plugs and connections? or would you have to rewire the whole truck for the new 3.3l motor? -
so are we opening the february nomination backups
Precise if you really could rip the bumper off your rig and make up some CAD dimension you would be my SAVIOR !! I have the welder and am ready to build it im just HORRIBLE with the geometric design ! PLEASE HELP THE FORUM OUT!!
can we still put our trucks in for voting?!
haha first time i tried it ...i said its cammed out hahaha and i yelled "gentleman! Start your engines!"
well after all the headche and stress of getting rides everywhere.... i bought a $4.99 pushto start switch.... works pissah.
what color wire and location is sent back to the ecu for easier starting?
haha yes i know that 14m is a relay i dont know why i keep saying fuse haha. and i checked every fuse in the dash. all fuses are good replaced the inhibitor relay, relay 14m, clutch safety switch, new starter, and new ignition. is the ignition relay seperate from ignition because itself?
