27
Everything posted by Rebelord
Does anyone have experience with this? Looks very interesting and promising. But for those with snow, not sure how it may work out. Link: http://lokka.com/site/ Just scroll down a little bit and Search your Year/Make etc. They have them for the front. Nothing listed for the rear. Price: $389 shipped USA & Canada
Changing my pass valve cover gasket. They are supposed to be hard like plastic right? Lololol<br /><br />Sent from my Galaxy Nexus using Tapatalk 2<br /><br />
Going to take it somewhere or want to do it yourself?
Getting ready to lift, need some help/advice
Rebelord replied to grassnroots22's topic in General Forums
That I could not tell you. Need someone with a SFD to chime in. Or just give KRFabs a call tomorrow would be best bet. -
The only 2" lift springs available are the AC springs. (4x4parts.com/nissan). To lift the rear. I believe you only need the WJ adapters that also provide 1" lift with 4" springs. I'd call to be sure. Just that the spring rate is different for the WJ. So 4" gives us closer to 5.5 or so. At leas from what the FAQ says on there site. Oh, and while your in there. If you havent replaced your struts recently and they have age on them. Change them out. RockAuto.com for those. Rear shocks, according the the FAQ for the subframe drop, is to use 2002 F350 rear shocks. -
Find a place to get them mounted up? I checked out on Google map where you were talking about. Down south off of Card Sound road. Yep. that place looks fun. If you head that way, definitely hit me up. PM'd you my contact info.
Didnt get touch my Pathfinder. However, changed a fuel tank selector switch and selector valve in a '82 Chevy 4x4. Switch easy, selector valve. . not so fun.
Your old tires still good? <br /><br />Sent from my Galaxy Nexus using Tapatalk 2<br /><br />
Damn you are close to me. <br />I want to explore but dont have anyone around to go with me.<br />I found out about the Mudoholics. I guess there the only ones with tru permission to ride on the private land at 8th Street and 137th.<br />Other than that I dont know of much down here really. Since most of Black Bear is closed except for the tamer trails. <br /><br />Also i have pretty much street tires right now. So definitely need a 4x4 buddy if I get adventurous <br /><br />Sent from my Galaxy Nexus using Tapatalk 2<br /><br />
Shoes: Who makes those? Gabriel? Monroe?
Sounds good. Probably take a wheel off today to clean up and verify. <br />If it is 40mm then the wheels i like that are 16x8.5 and +18mm offset. Giving that the offset calculator is right. Would give me 3mm more clearance inside and outside would extend out 41mm past stock. Which will fit very nicely IMO. <br /><br />Sent from my Galaxy Nexus using Tapatalk 2<br /><br />
Banner Tire South has one. Dont know price but they've been pretty straight. Sometimes cheaper if you pay cash. <br /><br />Sent from my Galaxy Nexus using Tapatalk 2<br /><br />
Nice! Who are you going to have mount and balance them? Here is the link to find who had Road Force Balancing available. Which is worth it IMO. Link: http://www.gsp9700.com/search/FindLocations.cfm
I have been running the Valvoline Next Gen High Mileage oil. Usually you can get it cheap at Walmart like posted above. Plus, if it has as much recycled oil as claimed; then maybe we can say were helping the environment. Plus check advertisements for local auto parts stores. Usually they will have it on sale for ~2xx a quart plus $2-5 off any filter. Which I then usually pick up the Napa Gold or Mobil 1 filter depending who has the sale.
When its time, I'd support Fluerys and just order some from him. T6 Aluminum, threaded and Powder coated. Most of the machine shops around me would charge about ~$150 just to CNC cut/mill the spacers. No threading and I would still have to get em powder coated afterwards.
Didnt take the tire off yet. Yes, on the outside I have the usual 15x7 JJ some JJWWMM squigly markings. JDOT. Took a peak on the inside. There was some stuff caked up. But about the only thing I saw was WN5/S? and possibly a 40. But Ill have to take the tire off tommorow to be sure.
Guys, need some knowledge here. I have been scouring the web and I cannot find the stock wheel specs for my wheels. This is driving me bonkers atm. Reason is, I am wheel/tire shopping. Not quite ready to buy. But getting my "wish list" down. These are the wheels I have that I need the specs for: Factory SE 15x7 6spoke alloy wheels. These are the wheels I am looking at: Level 8 Scorpion 16x8.5 available in 18mm or -6mm offset. Depending on stock wheel specs determines which ones would provide the fit I am looking for. TIA! Rebelord
What is the normal water-temperature range for our trucks?
Rebelord replied to stioc's topic in 96-2004 R50 Pathfinders
Just did my write up of my install of my trans cooler in my thread. Linky: http://www.nissanpathfinders.net/forum/topic/35248-rebelords-19990-r50/ -
Thanks town. Got my cooler in. Will be updating my Member Ride thread on it. Instead of hijacking this thread. -
On the topic of trans coolers. Which line is in and which one is out on the radiator for the tranny. Installing a Hayden 678/9 this week. Was thinking of just bypassing all together. As I think my rad part may be clogged. When cold when I go in drive. Takes a sec to engage drive. But reverse is instant. Trans fluid is nice red not burnt smelling. <br />Live in South Florida so no cold temps. <br /><br />Sent from my Galaxy Nexus using Tapatalk 2<br /><br /> -
1.75 in / dual<br />2.0 out<br /><br />Sent from my Galaxy Nexus using Tapatalk 2<br /><br />
Did you set the timing? I believe its 15° +/- 2°<br />But check the FSM. <br /><br />Sent from my Galaxy Nexus using Tapatalk 2<br /><br />
Driver's Seat Won't Budge - Quick Fix?
Rebelord replied to Iceman2989's topic in 96-2004 R50 Pathfinders
Awesome to hear you finally got it! -
As this apply's to pretty much any modern vehicle. I need a replacement for my early 99 Pathfinder. Just looking for a good place to get one. Prefer NEW, but dont want to pay dealership prices of $100+
As I said in my post above. Pull your distributor cap. Then remove the cover in the distributor that covers the coil and ignition module. You can pull those using a phillips. Check and see if your coil is shorting out to the distributor. Plus check the module for any damage. Those symptoms are what I had when my coil ground out, then eventually fried the module. But if you can catch it early enough. You can find the coil solo online for fairly cheap. Over replacing the whole distributor like I did.
