Everything posted by AZ_Pathfinder
What are the measurements from the ground to the wheel wells on each side, now after the lift?? Sent from my iPhone using Tapatalk
Hey S4 what size are those tires that on your pathfinder? Sent from my iPhone using Tapatalk
Question About Pro Comp ES3000's?
AZ_Pathfinder replied to AZ_Pathfinder's topic in 96-2004 R50 Pathfinders
Perfect thanks again Rick! -
This may be a stupid question but would the bushing from the original shocks, the ones I'm taking off, work? Can they be removed? Thanks -
No any input is appreciated, I might need to see a picture to grasp it fully. Thanks, I might need to look at it, I just haven't had much free time. Sent from my iPhone using Tapatalk -
pro comp es3000 -
I tried to search this and didnt come up with what I was looking for. I remember reading some where a while ago, before I ordered these shocks, that they dont really mount up exactly right with our trucks? I was wondering what it is that makes them not just bolt right up? I've had the lift parts for a while now, need to find time to put it all on, but wanted to know what it was that I have to modify to make these work? I thought there was pictures of it as well, maybe from mudvaynes, cant remember. I think it had to do with the eyelets on the shocks maybe being to big?? Sorry everybody I really did try and search this first but couldnt find the answer. If one of you guys that use these shocks can chime in that would be great. Pictures would be better
I actually did end up getting those wheel spacers in the above link. I talked to the guy that was going to be making them and he said there should be no issues. Just haven't had time to put everything on the truck. I have a lift waiting, wheel spacers, cb radio, and I'm sure I'm missing something, lol.
So I wanted to get some hub centric either 1.25 or 1.5 inch wheel spacers. Here is the website http://www.motorsport-tech.com/special/truck/nissan_s?Next=31-45. My concern is I have Warn Manual Hubs on my pathfinder. The hub is 100mm on the auto hubs on our pathfinders, will a 100mm hub centric wheel spacer still fit over the Warn Hubs? The reason I don't think they will is that on some Toyota forums when I searched this online said they don't and that they had to use lug centric spacers since they had a larger center. Any help would be awesome! Thanks. Sent from my iPhone using Tapatalk
New Goodyear Authority A/T's
Yeah I'm happy with them, for the price can't be beat. Sent from my iPhone using Tapatalk -
The final word on lifting the R50 at a low Cost
AZ_Pathfinder replied to fleurys's topic in 96-2004 R50 Pathfinders
ok so with the 2 inch spacer, gives me 2.5 inches up front to level it I'll need the 3 inch rear spacer to level mine at 35.5 inches at all fenders. so with that in mind would these shocks work? Pro Comp #326506 Es3000 Series Shock Extended length 27.07, compressed length 15.94, travel length 11.13 -
So just to clarify, I dont have extended length coils, in fact theyre old, as in the original ones. So you think adding the 2.5 on the front would not be advised, even on old run down coils? If so that .5 inches isnt a big deal then. 35.5 inches would be fine. I just know Ive seen people with OME and AC coils add 1 inch spacer on top of those, which I would assume is around 3 inches in the front. -
So fleurys, if i want 3 inches in the front I need a 2.5 inch spacers, so my 33 inches goes to 36 inches. To keep the back level, as it sits at 32.5 inches now, I would need to order 3 inch spacer? Is this correct? I Dont want the rake look nice and level. -
So quick question guys, on the pictures of the test truck the front measurements are slightly shorter than the rear. For example the stock measurement for the front at the fender is 33 inches and 34 at the rear fender. So my issue is that my measurements the front sits at 33 inches and the rear sits at 32.5 inches? Do you all think this may be due to bad shocks? My main concern is that if I base my order on what the truck on fleurys page, his leveled out due to the half inch more for the front spacers. so the 2 inch spacer in the front = 2.5 inches of actual lift, since the test trucks front measured shorter in the first place this worked out. So I plan on ordering the pro-comp ES3000 shocks, do you all think that with these new shocks my rear will be raised up and not so squatty, so higher in the rear vs lower in the rear as i sit now? I just want to avoid a ridiculous reverse rake look, I dont mind it being slightly higher in the front, but not an inch or more difference. -
So I got new tires on the Pathfinder a few days ago. I loved the last set of Firestone M/T's that I had on my Frontier, but didnt have the $$$ to spend on those plus I dont have a lift on the Pathfinder yet. So While looking at options for A/T's, I remembered seeing these at Wal Mart and thinking these look nice. Did some research online and read a lot of good reviews. I love the aggressive tread, very M/T like tread. The price was right so I decided to get them. took them up north to do some fishing last weekend and did well. We'll see in the long run how they do, but so far I like them.
So a quick question for you guys that have installed these spacers. If you put these on and still use the old original springs, non AC, OME, etc.. Did you get the full lift amount? For example if you bought the 2 inch all around setup, with the old worn out springs did the spacers provide said amount of lift? Or did the old saggy worn springs Prevent the advertised amount of lift? Reason I ask is I was going to replace my springs with just new OEM springs non lift, but ran into some unexpected expenses and now budget is tighter than I had expected. So I would now just be replacing rear shocks and adding spacers into the old struts and old coils. Any input would be appreciated, thanks. Sent from my iPhone using Tapatalk -
oh wow Rick youre selling the Pathfinder?? Man someone is going to get a nice Pathfinder. That how I felt when I sold my 06 Frontier, he got a hell of a truck.
Anyone know or have contact with 96se4x4?
AZ_Pathfinder replied to 96Pathfinder4x4's topic in 96-2004 R50 Pathfinders
Man that stinks, at least it was only $9.00. Couldve been a lot worse if it was a big $$$ item. Good Luck Man, hopefully you get a resolution to this. -
Kyle if I can find a decent SE one and can make it fit on mine, the LE grill is yours! Thanks for the input!! Sent from my iPhone using Tapatalk
That's exactly what I was seeing to nunya. It's hard to find r50's around here at the pick in pulls. I'll keep my eyes open to see if one comes up and see if it's the right grill. Sent from my iPhone using Tapatalk
So I was wondering are the post facelift grill types swapable?? What I want is the honeycomb looking on vs. the one I have?. Anyone know if this is possible?? pics for reference Mine: What I want:
68k miles wow what a find!! Welcome! Sent from my iPhone using Tapatalk
