CrazzyMax
Everything posted by CrazzyMax
  1. This interest's me. I hate the WD21 dash, i saw a 94 HardBody, and was thinking in swapping the dash also, but i forsee a lot of work
  2. When i had 31", it was the only time the speedo was correct
  3. Off course that these Fender Flares in FG will be used only for Mall trails
  4. Yeah, put those pillar gauge pictures, because i have 3 gauges to put in my other Terrano and i have to modify the pod
  5. IMSA??????? This is FiberGlass, i'm no wizard, this was the first thing i made in FG, it's not finished yet Still need some touch's, doesn't look like, but its 5" wide
  6. I spent a lot of time looking for flares, but nothing came up, so i did this
  7. Hey JMorgado, whats up Are you looking for CV Axles or Solid Axles?
  8. The TD27 is a great engine to improve performance. Things that you can do. The exaust has been said before. The air filter, remove that filter and is box, i've put a Land Rover box and air filter with twice the size of the TD27 one. Turbo, mine is just at 1 bar, i don't wan't more, because probably would brake faster. The fuel pump, here's is the master mind, mine is just tweaked a little, 2mm of advance, a little more fuel, but a good fuel pump house, can modify the fuel pump, and tweak it, and the TD27, can reach 160hp with that. Mine has only 134hp, but soon it will have a modified fuel pump, to reach about 150hp , its more than enough, and it will reach 6000rpm
  9. I have a top mounted intercooler on my blue Terrano, but on my grey one , i'm going to mount a front intercooler, probably from a Audi A6 Allroad, but with some mods
  10. If you have good shocks, you won't notice much
  11. On Renegade i have 32x11.5x15 BFgoodrich MT on Dotz Racing 15x8.5 et -30 On SH i have 275/60r15 Fulda Tramp
  12. My idle adjust isn't there, its lower, next to the fuse box Its here, and it's stock, like all other TD27 that i know
  13. I was looking for pictures, but this is the next best thing i could find
  14. Mine is made out a of metal tube with a 72mm diameter and a 3mm thick wall, it's was the only measures of tube that i could make the curves without bending too much. Sorry for my english
  15. Mine leaks also, but its from de top, when its full it leaks
  16. I had the same problem, no white smoke, no oil mixing, just air in the water circuit. I opened up the engine and it was just the head gasket. (in the year before i did a gasket check and replaced it with gasket that wasn't Nissan) I put a new one bought at Nissan, and so far, runs great.
  17. The simple fact of changing anything here, is reason to apprehend the vehicle. Everytime i drive by a cop, my balls get smaller :confused: It's a ****** country. :oops:
