Everything posted by Puckstoper9
Received mine yesterday. Painted, so the painted ones are on there way.
http://victoria.kijiji.ca/c-cars-vehicles-cars-trucks-2000-Nissan-Pathfinder-SUV-W0QQAdIdZ390279307
Great job looking after this for us.
That looks sweet. Now I am getting exited. What gauges are everyone planning on putting in?
Dowser, I hope your daughter is getting better. The main priority has to be Family. At this point I would have to say that a bit more delay is no big deal.
I second this. Was one of the problems with mine when I got it.
factory service manuel for 1983 720 hardbody pickup?
Puckstoper9 replied to smoke's topic in General Forums
The hayes manual for the 720 is the same one as for the wd21 pathfinder and hardbody's. -
There is a relay for the fuel pump that is located in the foot well on the passenger side. Also check out http://www.720world.com. There is a ton of information on there and a few guys that know the 720's inside and out. The fuel pump is not inside the tank it is on the outside of the frame rail in front of the passenger rear tire. If you still have the original carb you will have a fuel filter in the carb and one before the fuel pump. -
If i remember correctly there are not factory relays for the head lights. the factory system runs through the headlight switch only.
Looks Good
Posted on NOAS
Crazy things the previous owner did...
Puckstoper9 replied to ChatWithaNinja's topic in General Forums
The previous owner replaced the fusible link (Green and black one) with a piece of wire stuffed into the connector and wrapped onto the battery post. It wasnt secured at all. -
More Center Console Discussion
Puckstoper9 replied to Inyourface1650's topic in 90-95 WD21 Pathfinders
You would have to use the Hardbody style parking brake. The Xterra has the parking brake under the dash. -
Count me in.
I would definitely bleed the system and see if that helps. It did help for a little while with mine but the symptoms returned. After changing the master and slave cylinders no more issues. My slave cylinder was not wet it was sucking air into the system.
Sounds like a clutch to me. Had the same problem, tried to bleed the system and could not get it to bleed. Ended up that the seal on the slave cylinder was leaking.
Question about rear height stock 31's
Puckstoper9 replied to ahardb0dy's topic in 90-95 WD21 Pathfinders
Those would be weights. Looks the same as mine. I noticed when I put new 31's on my pathfinder I had a rub when turning to full lock. But it turned out to be my mud flaps weren't attached correctly. -
Are you sure that the amp is not blow. When I got my truck I had to by pass the amps. They where done.
The control arms don't provide any lift. The lift is achieved by cranking the torsion bars. Replacing the upper control arms is done to correct the ball joint angle.
Put a new set of 31x10.5R15 Dick Cepek Crusher tires on. So far good on the pavement, and they look good.
I have an alpine unit with sirius/XM and replaced the stock speakers. The paper was gone when i took out the stock speakers.
I live about 2 hours from there but I do not have a extra pillar if that helps at all. Do you know if they need a pillar out of the truck or would it be more helpful to see one in a truck.
