Omg. I am getting hacked. So if you have followed any of my post then skip to the next paragraph. For those that need the details, here you go. I replaced my original engine with a used engine from Texas. (supposedly a JDM) whatever. Either way I used the original tb, intake and lower plenum. I didn't trust the used one. Looked full of dirt. So the perfectly working upper end of the vg30i came off the original. Worked when the head gasket blew (no rebuild as the heads cracked and I couldn't buy a head for a 1/87), but it didn't work after I installed it on the replacement. The engine idled and ran great except it would not rev past 3,000 rpm. No matter what. I actually drove it 200 miles this way. Nothing changed. No biggie I thought. I checked the ECM trouble codes and found a 12 and a 43 (I think that is right). Basically MAF and heated O2 sensor. Whatever. So I tested the MAF through the on board diagnostics and it failed. So...
Then I bought another MAF from a guy on here and it was a known good sensor. The sensor looked great and when I installed it it changed my issue. Now instead of not being able to rev past 3,000 rpm, it idles like a beast. It also chugged black smoke like crazy. I let it warm up and it started to get a lot better. I thought maybe the ECM just needed a minute to clear up. When it did I took it out for a test drive. It ran beautiful! Full power, redline and all. I could smell that it was running rich, but hardly and black smoke. Only at high rmp. But half way home it all changed. Instantly it went back to not being able to rev past 3,000 rpm and before I knew it the only way I could get it off idle was if the clutch was disengaged. Neutral it would misfire and sputter to 4,500 rpm, but under a load it had zero power. Not even a little. Then it started to die and chug black smoke on start up. Then it was back to the loping idle and black clouds of smoke.
A lot of useless details here I'm sure, but I thought it wasweird how it got better and then worse. This all just happened so I haven't checked the ECM for any codes yet. Anyone seen this happen to their rig? Maybe you have some suggestions for a guy tring to drive this ole' 87 home soon? I will post any new findings tomorrow morning. Hopefully this is common enough to pinpoint the issue without me losing my temper and posting the whole thing in the for sale section
