NightWolf
    Terrano 1991 model black
    Screwdriver Mechanic
    Terrano R3m
    Western australia
    Australia
NightWolf's Achievements
  1. i went away for a 4 days trip filled up before i left 65lts and some coming home total 109lts and did just over 1000kms in distance pretty happt for that did some 4x4ing as well with that
  2. for a full tank i get 650 to 700 kms on $50 between 32 and 36 lts i get between 250 and 300km
  3. ive been to several places in aus and cant find air filter any one know the part numbers brands that can be used in aus for the terrano thank you so much
  4. thank you for the answer so 2wH all the time then so when do you use the 4x4 will it do it on a beach what if on a hardish track what do u put it in
  5. 1991 teranno rever in 2w is perfect turning in reverse is fine but in 4x4 mode going striaght back is okish but turn it shakes like its trying to grip or something only does it in 4x4 mode revers back tunn and its just hard couldn't imaging it would be any good fon the beach as it would dig down
  6. can any other rubbers be used for the front sway bar pins seems my right hand side the rubber to broke and the pin is loose
    1. nunya
      nunya
      my front sway bar links are a cluster-you-know-what of bushings right now. Try to keep same overall length between the bar and control arm and don't leave tons of excess thread hanging around to get caught on crap
    2. nunya
      nunya
  7. checked oil and cap ect no water in oil so either pund isnt pumping or the radiator is stuffed
  8. god dam it car just had steam coming out of it first realy hoy day in a while might need a electric fan
  9. ? is there a way to get the decals of the doors ect without scratching the paint work
    1. Show previous comments  3 more
    2. k9sar
      k9sar
      peel it then use coleman fuel to remove the residue
    3. Trogdor636
      Trogdor636
      I pulled the factory decals off my black 94 Hardbody in 99. The difference in blacks were amazing, I wouldnt do it again.
    4. Tungsten
      Tungsten
      lol paint fade
  10. why is that after i change motor oil it starts slipping in gear alot more
  11. Dam it someone reveresed intomy rear door today not happy
    1. Reshma
      Reshma
      it must have been a jealous JEEP.
    2. Tungsten
      Tungsten
      you should see the back of my truck
  12. ? in aus what oil filter do i get i just noticed on the current folter there is oil all arund the sides of it and i need to do a il change
    1. jadm4x4
      jadm4x4
      if its a vg30 i use a ryco Z145A. any parts mob will have them
  13. can any one tell me are the Window Motor Regulator the same in pathfinders for the windows my terrano needs one asap and cant find one yet just wondering if pathfinders are the same or some other nissan car has the same ones as the terrano thank you
  14. do any other nisians share the same power window parts i need one asap or i cant go anywere
    1. Alkorahil
      Alkorahil
      In the US it also fit the 1997 D21 truck and the pathfinder from 90-95
