Everything posted by Nick
88, I love the "Team Meow"! LoL
The high here is $2.19 and low is $2.00 and thats prices for 87 octane!
LOL Anyone willing to loan me there pathy? she said she would do it.
Ive got a pic of my fiance standing next to my pathy, shes not in bathing suit but jus tthought id share
Although I dont have a pathy anymore I think Jims idea is excellent. Its a good way to get exposure for NPORA and a good way to get exposure for newbie models. I like the idea as long as you dont get to offensive with the pics.
Well from seeing first hand what can happen I feel the filters are a good idea. All I can say is keep up the good work Jim, your doing an excellent job.
Not sure what it is but to me it looks as if it had once been re-welded.
Im not sure if this makes a differance, but if you read that is a Pathy PreRunner, only prerunners i have seen are on the dunes, and I think they usually run in 2WD. Correct me if I am wrong though.
Thats awesome, Id love to do that to mine, I gotta 350 sittin in the garage, gets me thinkin
I know what it takes for a swap but i mean where on the site are you guys seeing a swap??
Where are you guys seeing a 350 swap? If its doable Id like to learn about it, I gotta 350 that was just rebuilt sittin in my garage.
I think this is the link you wanted to post?? http://www.fly-n-hi.com/FST/nissanpathfinder.htm
I think you stated it really good k9sar.
Not that I know of, the reason you cant see good in fog with brights on is they are pointing up higher. The way fog lights work (to the best of my knowledge) they aim really low to the ground to help you see whats right in front of you. Correct me if Im wrong.
I guess if you wanted you could mount them to the stock roof rack Just an idea...
Wow nice story and pics Jim, Id love to pull some people out here but with the bald tires that would be alittle challenging But someday my pathy will be might enough to help out the community
Well tif22, Im not sure I understood most of what you said but here it goes . Coming out of your stereo you have a wire (usually purple) called the remote wire. What this does is either send power to the antenna, to make it go up if you choose to do that. Or you can do what I did on my friends pathy and hook this to the wire on the wiring harness for your amps. Then your amps will turn on when you turn the deck on. As for the illumination wire, Im not to sure what that is for. In the 10 stereos I have installed I have never used it so I can't really help you there. If you have any more questions or if I didn't answer the remote one clear enough please feel free to ask.
Hello and welcome to NPORA Forums, firstly I would like to say welcome. Also please don't post 2 topics that are exactly the same in different threads. (makes confusion among members) I have personal messaged you and I have deleted the other post and edited steves post to show what he wrote in the other topic. Thank you. (sorry if I came off rude, not intended)
Welcome to the Forums Roost!
CV Axle Replacement Written by Piscator and OffroadX Posted by Nick Estimated Time: 1.5-4 Hours Last May at the Nissan Net Run down in JROCC I discovered I had a blown CV boot, the joint was already thunking and clunking so there was no point n replacing it. I finished the weekend on it and started searching for a replacement. It was looking like I was going to have to spend at least $150 for the part when my friend and fellow Nissan owner OffroadX said he had a line on one on Ebay. He sniped the auction for me and I got the axle for $35 including shipping. Looking in the Factory Service Manual and Chiltons/Haynes guides as well as Alldata I saw that the job, while not all that hard, was scheduled to take 3-4 hours. It did, the first time, the second time we did it in under and hour and a half. I highly recommend having someone working with you as a helper. The job will go faster and be way more fun. Again, OffroadX came to my rescue and worked with me to get this job done. Block the rear wheels and jack up the front of the vehicle and put it on stands, remove the wheel on the side in question. I suggest removing the wheel from the other side too tho you don't have too. Put the Transmission in neutral and the T-case in 4high....You'll need to slip from 2 to 4 high at different times to lock the driveshaft while accessing and loosening or tightening the CV/Diff bolts. Remove the five bolts attaching the axle to the diff. NOTE these are 12 point bolts you *MUST* use a 12 point socket to remove them. An air wrench or air ratchet with a long extension makes things nice and easy. You're not going for high torque so I just used a regular 8" extension to reach in there. Be ready to use a strap wrench to turn the front driveshaft so the diff flange rotates to allow access to all the bolts. Open up the 4wd hub and remove the snap ring holding the axle inside the wheel hub. Disconnect the outer tie rod end from the front of the knuckle. Remove the disk brake caliper and wire it up out of the way. Carefully use a jack to lift and support the lower control arm, keeping an eye on the nearside jackstand to be safe. Unbolt the four bolts securing the upper A-Arm to the ball joint and wire it up out of the way too. Use your hand to turn the steering knuckle to the right as far as it'll go (for removing drivers axle, turn left to remove the passenger side axle) and rotate the wheel hub out and down towards the front. Work the axle out along the frame towards the rear. At this point you will likely end up determining the shock has to be removed as well, do so if required. There is only about half an inch of clearance but there IS room to wriggle it out. Use a jack to raise or lower the lower control arm and wheel hub if needed. Make sure that the spacer came out with the old axle, it’s a copper alloy washer about an eighth of an inch thick that goes over the outer end of the shaft and rides against the back of the wheel hub. If you leave it in there and your replacement axle has one on it too, you won't be able to get the snap ring on and you'll have to uninstall it and start over (mind you'll be able to slip it out and back in about an hour this time If your replacement axle is used and has one on it already, stick with the one that came with the replacement. Otherwise, re-use the one that came off your old axle, it shouldn’t be too thick to prevent the snap ring from going back into place. Grease the splined axle shaft and slip the replacement axle in the same way the old one came out. Bolt the inside end to the diff with the five 12 point bolts, Install the snap ring in the hub and replace the hub cover (for Manual hubs Autos require more doing) Replace the tie rod end, be sure to use a new cotter pin. Replace the shock if it was removed earlier. Lower and bolt the upper A-Arm to the upper ball joint. Replace the caliper. Test the 4wd action making sure everything turns OK. Replace the wheels, lower the wagon and test drive. Have a beer, you just saved $400 which you can now spend on other mods.
Haha, my girlfriends dad says anyone who drives a jeep is (cough cough) cant say it here But you get the picture. Hey they should make LandCruisers now like the F-40 Series, now thats a good trail rig.
Should just screw in if Im correct.....
There is a relay for the headlights and check the wiring harness the connects to the button for your fog lights, maybe it came disconnected, happened to me b4.
Haha, glad I could help
good point denisb, i have a lit switch also, and mine also it too bright. So to solve this i put electric tape around the switch but lef the top untaped so I could still see a little bit light up
