tsailor21
Everything posted by tsailor21
  1. is it true that the 3.3l from a 96 -04 pathy will work in my 92
  2. hey thanks for the quick response ya i hand a 91 plymoth laser that did the same thing. i figured i have bent valves. do the timing belts on pathys ever slip?
  3. Hello so i was driving home yesterday at lunch tim and my pathy just died when imwas driving so i pulled off on a back road . When i trien to restart is spun over like there was no compression. just wondering if the distributer would still turn if the belt was broke? please help thanks much in advance
  4. i also need a new clutch will that make it shake a bit on take off?
  5. yes its 4wd and i just changed the fluid and it looked fine
  6. Hi all so i noticed the other day that when i take off my rear end seems to almost bind a little but once i get rolling its fine any ideas thanks tj PS: my pathy has the factory LSD is there some bearings in there that can go bad ive never had it apart thanks
  7. when the parts guy looked it up it calls for dex 3 atf but that was a parts guy loking it up im gonna call nissan to be shure
  8. its a MT so wht fluid do i need to use in the tcase
  9. hi all im going to put my oul tcase on my newer tranny and i was just wondering if there is a gasket between them of if i should just use some rtv also what fluid and how much do i need for a 92 t case thank tj
  10. ok so i got it mounted and all the wires and coax run. it is mounted under the radio where th abs box was mounted. it turned out that it just bolted right in and the coax is run in through the rear hatch and under th carpet all the waty to in front of the shifter. i used a metal coat hanger to help route the coax and i wired my power from the cig lighter so i will never get left on thanks for the help and pics
  11. hi all i am in need of new leathers for my front seats, i bought my pathy from new mexico so thr front seats are all burnt up so i was wondering if anyone knew where to get new ones preferibly stock seat covers thanks
  12. how do i get the coax from out side to inside the cab?
  13. ok so if i mount the antenna on the rear tire rack how do i go about running the coax in to the cab
  14. OH ya how much coax will i need to mount my antenna on the rear tire carrier thanks
  15. hi all i just got a CB from a friend but i dont know where to mount it so that it is out of the way. i want to mount it below thw stero but I took of the plastic and there is this black eletrical box please help
  16. what are the 2 slots for on the front and do your front signals still work with that bumper
  17. would a 4x4 sheet of steel work to do just a front bumper?
  18. I was more wondering what you used for a template to cut them out thanks
  19. how did you cut your fenders? they look good also wondering whatyou used for mounting brackets
  20. new kally safari TSR tires tomorow
  21. just wondering how much steel you used for thr bumper and how you made the mounting plates ? thanks TJ
  22. hi all just did a search and couldnt find if i neen to get longer brake lines for a 3'' lift so if any one knows please let me know thanks alot tj
  23. ok so i did a search and did not find any thing so if you know the link to this topic can you let me know thanx a lot
  24. hi all since i bought thr finder the fog lights have not worked so yester day i was trying to get them working so i replaced the fuse and relay and i still have no powed at the plugin also i see the swich has 4 prongs on it and only 3 wires should there be a fourth wirs on the plug ? thanx tj
  25. oh ya like what kind of tips and tricks are you talkig about manual locking hubs and eletric fan because i have a set of fans for a 91 maxima and i was wondering if they would work on the finder but let me know all the mpg tricks also i am puting a 5 spees out of a 96 -99 in my 92
