kefferjoe
Everything posted by kefferjoe
Looking at this pathfinder price too high?
kefferjoe replied to kefferjoe's topic in 96-2004 R50 Pathfinders
They dropped from 5600 to 5000 within a 15 minute call back. -
The offer is now at 5k is that still too high? That's way lower than NADA and edmunds but still higher that KBB. I mean others in the state from private retailers are going for 3900-4400 and they have less miles on them. I really want it for the 5-speed and the '03 roof rack. But I don't know if it's worth this much. -
http://santafe.craigslist.org/ctd/4088000125.html kbb goes for around 4000 on this vehicle NADA for about 6800 whats the difference between the two? He said $5600 cash. What should I pay?
Hello I recently destroyed my 98 Nissan pathfinder in a mud puddle engine is shot. Instead of replacing or rebuilding the engine I decided to upgrade to an '01! Now here is my question I purchased bumpers from Tactical armor group (front and rear) and a lift from A/C and a few other things. My main concerns are the lift and bumpers will those fit from a 98 to an 01 or will they not?
What is wrong with this pathfinder?
Hmmm well this has all been helpful I think the reason why he would have used late 90s parts is because they are everywhere in the junkyard around here where as the 2000s are harder to come by. My next question is when you all refer to the "clip" does that mean the fenders and such or would that also include the radiator core support and stuff. I might want to pick this vehicle up and reconvert it to an 01. Assuming he lets it go for cheaper. -
http://albuquerque.craigslist.org/ctd/4006134987.html 01 pathfinder with late 90's front end?? Opinions??
So I'm sure it was just the pulley but why wouldn't my car turn over? Without the fan belt engaged?
Water pump pulley failed this weekend. The belt flew off while I was driving down the free way. The pulley was insanely wobbly so I sucked up a towing bill and had it towed to a shop. I could do the water pump myself but my concern is that while this happened that something happened to my timing and if so what are the chances that I broke valves or pistons? I did smell smoke after the belt came off and the car won't turn over. Also the lights that came on when this happened were the brake battery and a/t light (maybe just letting me know the alternator wasn't going) any thoughts on if something happened to the engine?
Well in my case I know because if the engine is cold and look up at the exhaust manifold from under my truck I can see a large crack running perpendicular to the block
Yeah i was looking around and the shops around here want close to $300, and that's just labor assuming they don't have to replace studs and such. They quoted 3.8 hours for the job. I may just do that since it does look like an insanely tough job to do.
Hello, I have a cracked exhaust manifold on the underside of my driver side exhaust manifold. I am trying to decide whether to take it to a shop to have it done, do it my self, or to just leave it be. I'm fairly handy with tools, but my concern is if i was to break the studs off the manifold due to rusting. Also I have no idea how time consuming this project is. How much would a shop reasonably charge to do this? How long would it take for me to do it myself?
I changed the shifter of the pathy from one i found at the junk yard (this one looked a lot nicer). I believe it was 2 years newer so approx a 99....could this be an issue? I also notice that if i want to turn o/d off i have to hold the button instead of pressing it.
I have like 6 damn clusters in my garage...let me tell you if you get one at the junk yard make sure it is the exact same. I pulled 3 off of 97 pathys and all of them were different and they all caused their separate issues. Also the gauges you get from the junk yard tend to have high mileage so make sure to get the odometer set to the right mileage
So I have a 97 pathy and my cruise control used to work but now it doesn't the light on the dash does not come on but the light on the switch does....hopefully a fuse? Any ideas appreciated. If I can test something let me know as well. Thanks!
I took my doors off once apon a time...there is actually wiring harnesses that make the process very simple. I also welded up some 3" steel tube doors that go on the front...have to mod them they rattled a lot. I will take pics when I find them (got buried in the shed for the winter) they didn't have speakers or any fancy stuff. Just there to keep me and the passengers safe while cruising
ah that must be it! Thanks for the tip because I do change the oil, and it was the driver side! Absolutely genious!
So I went on an off road adventure last weekend and when I was done, I had the worst steering issues. Turns out the rack and pinion mount bushing isn't just bad but it isnt there. It's just completely gone. Ho this happens I don't know. So I ordered the bushing from nissan 14$ a piece i will replace both of them. My question is how hard is it? Do I just unmount those bolts and slip the bushings on or is it harder. I'm away from home at school so my time is minimal and my tools are not abundant. So if it is too hard or too time consuming ill let the dealers do it. Thanks in advance.
Could another issue be that maybe my control arm is bent in some freaky fashion
Yeah something definitely looks wrong but idk what it is mine was taken at full weight on suspension I have the a/c 2" lift and snake racing approximately 1" spacers and that's it I have taken this apart 3 times and it has gotten drivable but I can still feel the jumping around corners I did however find a copper washer in between the cv axle and the inside of the hub where the dust cover and cv axle meet this might be causing some issues its about 1/4 of an inch thick I took it out but I have yet to put everything back together and take it out for a spin
It's only 6 bolts I can't imagine I messed it up that bad but I will try taking it apart this evening
I'll take pics tomorrow when I do the sway bars with the wheel is off maybe I did something wrong on the install
It's not new my other pathfinder was wrecked and I bought this one for 500 so it was merely a lift kit transfer and this shock is kyb gr-2 And I had zero issue when it was on my other vehicle and it was thi exact setup I just took it off and moved it to the other vehicle
However maybe the turning issue is caused by not having the sway bars connected yet
http://sphotos-a.xx.fbcdn.net/hphotos-ash3/557562_3566713420723_1912955342_n.jpg Does this look any better?
Upon further experimentation I lifted the back and I returned my cv half shaft and got a new one....lifting the back helped very slightly buy replacing the shaft helped tremendously...I'll snap a pic later this afternoon to show the new angle it feels solid but I notice when I crank the steering wheel to the right and really gas it I will get the same thing happening I'm hoping that once the coils settle in a little bit and I put some miles on it, it will be better.
