giddyuppony
Everything posted by giddyuppony
Hey all, Looking to see what the feeling is on lifting a r50 with coil spacers? Also, I was wounder, what height is the max for the control arms in the rear before you need to get longer ones? this is what I am talking about when I say coil spacers. ( In case there was confusion) http://sfcreation.com/t/pathfinder-1996-2004-r50-platform
Hello All, This is a rather embarrassing thing to ask but I need to know where the powersteering reservoir is located on the 1998 pathfinder and i cant seem to locate it. All the images I have (Haynes and internet) show it in a location that doesnt hold true on my pathy... Reason being, every time i turn the steering all the way from left to right a loud squeezing sound comes from the car. The general consensus from the internet is could be a result of low power steering fluid levels. Correct? Thank you for your insight,
Strange "lurching" feelings while driving slow
giddyuppony replied to giddyuppony's topic in 96-2004 R50 Pathfinders
Also if anyone has an recommendation for what kind of OBD II reader that would be great too. thanks -
Temperature doesnt seem to make it better or worse. Its a manual. Not sure about the type of fuel in the tank, but it happens winter and summer. Running time also doesnt seem to make a difference. trany and diff fluid as changed about 2 months ago. thanks for the feed back. -
giddyuppony posted a topic in 96-2004 R50 Pathfinders
Hey, So, like the title states, im getting what feels like a lose of power to the wheels for brief moments while driving in 1st and 2nd without the accelerator pressed in. It's not a stalling feelings, rather a lurching. To try and give a rudimentary diagram: driving in 1st or 2nd accelerator pressed in-> lift off power-> crawl-> power lose-> second later power back-> lose of power.... until I give it gas again. Also, I get this when starting of a stop light or full stop in general. However, this could be better described as something holding on to the rear axle, but for a moment, and then releasing it. the sound that it makes is rather concerning. I was hoping to get some insight. thanks for your ideas. -
Yah I just found some on Amazon for 23-150 bucks. What should I look for? as in what companies are crap ect..
well better said where I live there are no Autozones
I live in canada and I dont think there is an autozone around here.
Yah I was thinking that 1000 was way over priced and thats why i didnt have them work on it. Im thing at the cost of 60-80 buck per sensor I would just do all of them at once, save the hassel. Does anyone still have the part numbers from the ones they used?
yah that what I was thinking when they told me the cost. Im not sure which one is busted, they wouldnt tell me, Ill call back and see if someone will just tell me now, its been a week, hopefully they will let it slip.
So I have been noticing that a) I was getting terrible mpg and there was some white smoke coming from the exhuast when I accelerated/ started up the car. So I started to check my oil levels, nothing. So I gave up and took it the garage. They hooked it up to the machine, did a diagnostics and found that it was an o2 sensor (1 of 4) that was shot. They wanted to charge me something like 1000 for all 4 and 350 for just the one that was busted. I did some research and found that parts on the Nissan parts site, they are about 150 a piece and read some articles on how to do it. My question is if anyone has done this and would care to tell me how hard it is. From the write up I feel like im am capable enough to undertake this, but I have been bitten off more then I can chew before and I'm a bit gun shy. I guess the part Im the least clear on is the reconnecting of the sensor wire back to the wire harness. If anyone has some input I would greatly appreciated it.
You speak of the "death whine" I was hoping you might be able to elaborate on that. As it would appear that my path 98 is doing some whining of its own. But only when the clutch is dis-engaged ( foot off the clutch, neutral or ingear) I have had the clutch re done and the whine is still there so I think its the tranny and would like to know how to remidy it ( as in alternative to getting a new tranny). Thanks
Any way that you might be able to post some photos?
So the engines service light came, so I took in to the shop for a little check up. Turns out that one of the O2 sensors is dead. From my conversation with the mechanic there are 4 in total, 2 for each cat. Now my question is are these difficult to change out, and is it a bit deal if I dont replace them?? thanks,
Thanks all for you comments. I'm going to take it to a new shop Tuesday and have them take a look. Ill post the results then.
Hey thanks for the responds. It has 188km on it. If I had the tools and/or the time I would have been out there fixing, problem is i am a student and really dont have the money either. Im an curious though, you say a trany is only $500? Hmm. What should I being searching for ( part numbers etc?) As for as a trany service yes it was done by the stealers when i was taking it to them, now i take it to a private shop.
Alright, so ill give you an intro into my trouble some situation. I have a 98 pathy and over the last 4 months I have been doing nothing but spend money to keep my truck on the road.(Break and Bearing (front) $540 & Clutch $1600) and now the trany has to by fixed, there is a bearing loose in there somewhere and its making a whinning noise and potential will lead to a lot worse, or so i have been told($2000). Also the values are leaking oil up front and its causeing a terrible smell($500). And now I find out that there was an issue with the way they did the timing belt as it would appear the water pump and then serpentine belt werent done, so really everything in the timing belt area need to be hauled out and re done. And i Know that the control arms will have to be done sometime soon, despite not getting any of the wobbles.($1200) So the issue is do I fund this or sell? I will tell your right now that this car is truly well kept, oil change, filter changes all of it done and reorded. I got this car as the 3rd owner, my parent before me. It hasnt got a spot of rush, garage kept since we have owned it. As I read over this now it almost slaps me in the face with what I should do, BUT I like this car. So I guess I was wondering if anyone else out there has been at this cross road and the choices they made. Thanks, PS. If I did re buy it would be a Nissan either 03 R50 or Xterra.
this is awesome Is there any way you might be able to put some more photos up and a little description on how you made it. I would like to try and make one, but the MAS would be my hesitation.
Hey so I have been wondering this for sometime and I have look at a bunch or manuals and they havent told me anything. ON the rear view mirror there is the display for the temp and direction, but it also has this strange little light up sometime with and ICE light on it. I cant figure out with that is supposed to be telling me. Is it because there is ice somewhere and a sensor is too cold or is it telling me that there is ic on the road( I highly doubr this one but hey just thought i would ask). So its not like its a huge issue, more like I want an anwser to a question that ever winter i have. Thanks,
Hey so I have had my pathy for 5 years now and I have been noticing that over the last 6 months of so the clutch has been getting tougher and tougher to push in. Simple question really, not sure if the answer is as simple, but how can I make the clutch easier to press in?? Is this something the dealers/ shop needs to do or can i do it myself with a limited amount of tools??\ As always any help is greatly appreciated.
Umm not sure but when I was looking OME doesnt make a 2 inch lift for R50's. If they do and I am mistaken please tell me where you found them, because all I can find is a 1.75" lift.
Yah I asked fleury and he suggested that it might be something with catalytic converter. Im going to have them look into it when it goes in for some repairs, some dumb bitch hit me today and smashed up my front passenger side and royally fskced up the bumper and wheel well. The steering is mangled and there will be some fixings to be done. Lucky though, because had this been three weeks later all my new suspension would have been put on and wouldn't be replaced. Im pretty pissed as it is. stupid drivers :stickwack:
Ok so I accidently posted this on the wr21 page, so they gave me some ideas about my blower motor and needing to clean it out. But I just wanted to see if anyone here had the same issue. Ok every so often ill be driving along an my pathy will start smelling like blown out candle smoke. I have tried to narrow it down: It seems to be strongest after do a long turn where the wheel is cranked fully over, when i have been in traffic and there has been a lot of stop and go(so lots of clutch work), and sometime just when it feels like it. Anyone have a clue? There are no fluid leak coming from under the car, checked that, oil levels are all good, brake fluid is fine...etc. Im really weirded out by it all. any thoughts?? So after getting home from work, the smell was there again, but only could be smelt from out side. So im going to go ahead and assume its not from the blower motor. The smell was strongest right under the divers door.
Yah I dont need it burning up on me.
