Everything posted by RustyButTrusty
So the 4th fan speed doesn't work for my heater/ac controls. Whenever you slide it to the 4th speed the fan cuts off, no movement all all. I was thinking maybe the resistor was bad, so I replaced it with a working resistor, and it still wouldn't work. The only other things I could think of that might be causing this is a break in a wire, or possibly corroded switch/connecter. Anyone else had a similar problem, or have some ideas? Thanks!
Where To Get Lego Wheel Center Caps
RustyButTrusty replied to JamesRich's topic in 86.5-89 WD21 Pathfinders
There are quite a few in pretty nice condition sitting in the junkyards around here. -
88 has 284k 95 has 185k
Factory Fog Light Switch
RustyButTrusty replied to RustyButTrusty's topic in 86.5-89 WD21 Pathfinders
Dharidson, would you mind telling me if your dash mounted fog light switch is mounted in a round or semi-circle shaped hole. The plug (where the dash mounted switch would go in my) is fitted into a semicircle shaped hole, but the switch won't fit into it without some drilling, and I don't want to drill unless needed. -
Kinda seems odd though that dharidson and me have the same exact one in the same car. Maybe they were factory just used if the rectangle rocker switches weren't available or didn't have a free space -
I am thinking about possibly installing a factory roof rack to my 88 (which never came with one). Will the racks for the 4 doors work for the 2 doors or are they completely different? I'm looking for something somewhat easy to install requiring little or no modification (besides drilling etc), and I'm also wanting to avoid a leaking roof as well as added rust problems. Is this something I should avoid? I also noticed that the 2 door rack I saw at the jy was held to the roof by pop rivets, while the 4 door rack was held on by phillips or torx screws. Thanks!
Does the hole that your switch fits in a full circle shape or a semi circle shape? The cutout for the switch in my dash in semicircle, but the switch is circular, so if i mounted it i would have to modify the hole. -
So yesterday I went to the junkyard and looked through some 20 pathfinders to see if I could find me any goodies. I got me a factory fog light switch (orange push pull) out of a 87 model where the switch was mounted under the rear wiper/hazard switches in the little recess on the lower part of the dash. Now on my 88 that I'm thinking about putting it in, there is a plastic round plug on the left side of the steering column underneath the dimmer switch and cruise switches. When I took the plastic plug out of the hole (where I'm guessing the switch would mount) the hole in the dash was a semicircle shape and not a full circle like the 87 model I got the switch out of. Does anyone have a picture of the factory foglight switch in the dash? Thanks!
Auto Trans Can't Make Up Its Mind
Ok well thanks guys for all the help, I really appreciate it. Currently the pathfinder isn't registered so I can't drive it too far. I'll check the fluid again (the correct way) and proceed from there. Thanks again! -
Yes it is on level ground. I checked it cold, should the engine be hot? Yeah it was the trans dipstick (thanks for the suggestion though). -
Ok well I crawled up under the car and verified that there is indeed a cooler installed right in front of the radiator. I traced the hoses connected to it to two metal pipes which then joined up with the transmission I am assuming. I just checked the fluid and it still seemed fine and it wasn't low. -
Funny you should mention this, I just asked my dad about the transmission cooler. He said the first time he had it rebuilt, the transmission shop put in a cooler, because they said it didn't have one. This shop was also several hours away, my dad had to stop there to have it fixed so he could get it the rest of the way home. He said they probably just put in an aftermarket one, since they were not at dealer. I don't know how reputable this shop was, but we've had several sketchy experiences when its been at different shops. Maybe they were just really pulling his chain. This is probably a dumb question, but can you tell externally if a cooler is installed. I've never messed with autos before just an old 3 speed manual. -
Battery is still in good shape, and alternator was replaced within the past 2 or so years. Sounds like replacing the cooler would be a good project once I get the funds up haha, I'll have to see if there is a write-up on here on installing one. -
Yes I believe it was falling out of overdrive, and I was running 31x10.50x15's. To tell you the truth, I'm not sure if the stock cooler was replaced or not, I would have to ask my dad to see if they did that when the transmission was rebuilt those times I mentioned. -
I would say so. Last time I drove it was 25 miles one way down the highway at about 65-70 mph, and it did it pretty much the entire trip. -
Ok, well the automatic transmission on our 88 pathfinder has been rebuilt twice. After driving it on the highway recently, I noticed it shifting from the highest gear back down to the lower gear down (I'm guessing 4th to 3rd), and it does that back and forth more so when going up a moderate grade. Seems like I recall a sensor or something being replaced on it alot earlier in its life for the same problem, but I'm not sure. Has anyone else had this problem and know how to fix it? Appreciate the help!
Outside Door Handle Broke
Exactly what I needed to know! I accidently screwed the plastic piece on where the male part was facining the wrong direction. Thanks again! -
Hi everyone, Just recently the icy weather caused the outside door handle on my 88 pathfinder to break. I have one I picked up from the junkyard, but am having a hard time figuring out to put the new one in. I have gotten the broken one out, and the door panel and everything off. What I cant figure out is where the rod attaches from the handle to where? The bottom of the rod has a circular plastic piece that is threaded on the bottom, I'm just not sure how this little plastic piece attaches to anything. Any help would be very appreciated, thanks!
Heater/AC Control Panel Light Bulb Replacement
Very helpful information. What holds the ac/heater control panel face on? I tried taking it off but it didn't wanna budge, and it seemed like it wouldn't take crack it. Also wondering if you can get the bulb from a auto parts store, or do you have to buy it from Nissan? -
Hi all. Being new here it looks like this website will be an invaluable tool. My 88 Nissan pathfinder decided to blow some light bulbs a while back, and I need to get to replacing them. Trouble is I can't figure out really how. What's mainly stumping me is the climate control panel lights. Haynes manual wasn't much of a help here. I'd really appreciate it if someone could give me some advice on how to replace them. I can get all the trim/panel off, and ash tray etc, but I can't figure out the rest. Thank you very much!
