muddawg
About muddawg
  • Birthday 12/12/1964
    I have a 93/se stock
Contact Methods
  • Website URL
    http://
  • ICQ
  • Yahoo
    rusty_ups2001
    ft.knox ky
  • Interests
    I enjoy offroading, bow hunting.Hey,I'm just an all around outdoors guy.
muddawg's Achievements
  1. muddawg
    manifold
    If you pull the heads, do you have to pull rocker arms and springs, i've never done this before,although im sure i can, its got to be better than pullin the engine to get to the broken studs.
  2. muddawg
    manifold
    I have a 93 se,broken manifold studs on driver side,Im having hell gettin to them, do i need to pull engine? need help. 4 broken studs.
  3. I have a 93 se pathfinder,Im thinking of replacing my engine,I seen on ebay where they have these vg30e engines for around $600-800,Has anyone purchased one of these engines or should I rebuild the one I have.Need some feed back.thanks
  4. I did an ECU check its givin me error 33,Is that the same as an O2 sensor? .
  5. "RECENTLY" LMAO!!. Anyway, Havn't seen the power light blink and I'll recheck everything.
  6. I have a 93 SE,I recently did a tune up on the pathy, plugs,plug wirers,clean the Mas sensor changed fluids new O2 sensor,new fuel filter. It ran great for a couple of weeks,Now,when taking off I have to push the gas pedal to the floor and it just crawls alone and then it kicks in, power light come on and revs very high ,trying to get to 60 Mph with the pedal to the floor is hard to do now.Is the pathy dieing? It only has 250,000 on it...LOL!
  7. Waiting on santa to bring that ALPINE, oooooh yeah!
  8. PANTERA.....COWBOYS FROM HELL!
  9. muddawg
    blown fuse
    OH YA,found the problem. thanks 88,the wire coming out of the headlight plug was grounding out.
  10. muddawg
    blown fuse
    Hey guys,I have a problem with my right head light. when I turn the high beams on, the right head light- fuse blows everytime.any tips on what i should look for? thanks.
  11. Hey guys,hopefully I can help,If you have auto temp controls on your ac/heater,there are two diodes, one is in the fan switch the other is in the temp switch.and also there are two bulbs on top of the unit,look for a small door...open it there are two bulbs gray and black,they're dealer items and quite pricey too.I have a pic of the unit hopefully it'll show.
