gacruiser
1991 Pathfinder SE with Sport package 31x10.5 BFG AT KOs 3" AC Suspension lift on the way TMJ Bull Bar Winch Bumper Hella Freeform foglights
45+
1992
Contact Methods
Website URL
http://
ICQ
Atlanta, GA
Interests
Offroading, competition shooting, hunting, camping, computers
gacruiser's Achievements
lookin' for ideas on dog proofing rear door panels
gacruiser replied to muttmobile's topic in General Forums
I had one for my '91. Just get an adjustable, universal model. They work great. If I had it to do over again, I would get one made of tubular steel. These can be found in most pet stores, Walmart, or Cabelas for $50-70. -
Febreeze is simply a masking chemical. As the previous poster said, get one of the enzyme odor killers (Nature's Miracle or Simple Solution are both good) from the pet store. If they'll kill the smell from a male cat's spray, they'll kill the mildew odor. The secret is making sure the source of the smell has been thoroughly saturated with the enzyme.
There's no way your 4wd is functioning if neither of your front tires is spinning....
Just fixed this same problem tonight on my '91 PFinder. I figured it had to be a relay, but none seemed to have a problem. No tach, no shift indicator lights, no voltmeter, no gas gauge, no temp gauge. Felt like I was starting off in 3rd gear (I was!). In frustration, I checked the fusebox. Blown "ignition switch" fuse (upper right - 10amp). Dohhh! -={Cruiser}=-
Yep, had a Mercury Cougar with a leaking modulator valve. Years later, believe it or not, had the same thing happen on a 1979 RX7 with an auto. Looked like a diesel running down the road! I don't believe the Pathy uses a modulator valve, though...
Some will disagree with my observations, but no, the switches to either side of the steering column are not backlighted. I bought my '91 SE new and they were never lit. I thought something was wrong until I looked at 2 other new 'Finders on the lot at the time and theirs didn't light either. A small oversight on Nissan's part, I guess...
Heater control and AC control lighting
gacruiser replied to prginocx's topic in 90-95 WD21 Pathfinders
I don't know about the 95 (the A/C and center console is slightly different), but just finished replacing bulbs in my 91 A/C control. There are 2 "wheat" bulbs (small, only available from Nissan) in my automatic climate control. These 2 bulbs light up the temp scale and the controls, including all the pushbuttons for vent control. The fan and temp slider knobs have LEDs in them and probably never burn out. You have to remove the control itself and partially disassemble it to get to the bulbs. The factory service manual was sparse, but gave enough info to get to the bulbs. There were a total of 7 screws attaching the control to the dash that had to be removed to get the control out of the dash. That was after removing the console bezel (4 screws), the radio (4 screws), and the ashtray frame (2 screws). The radio and ashtray could have been left in the dash, but it was easier to unplug the wires from the back of the A/C control with them removed. HTH, GaCruiser -
Actually, after doing quite a bit of online research, and not wanting to pay the high price for the Energy Suspensions Formula 5 grease, I found several options for urethane bushing lube. Most of the high-performance automotive crowd is using the Neo Synthetic Watercraft grease for lubing aftermarket urethane suspension bushings. It's main advantage is the use of teflon rather than aluminum for its anti-seize characteristics. It also has a wax base, which makes it waterproof and very sticky. One suspension website likes to use Permatex Anti Seize (in a tube) instead of the above, but again, the Permatex uses an aluminum compound instead of teflon. Because the Neo product is specifically made for applications involving water contact (food processing equipment, boat trailers, etc), it might be a better product for our offroad suspensions.
No, I wanted to keep the coils and use the airbags to level out my truck. The rear coils never lifted the truck up as much as the front UCA upgrade I made. That, coupled with the weight of the tire carrier makes the rear end sag giving my truck a "baja" stance. This gets even worse when I put the boat on the back and load it up with gear. Here's an older picture from right after I installed my lift kit: You can see the difference between the front and rear ride height. Air Lift Kit This was the kit I was considering as long as I don't have to order it from AC. I was not sure if the bags will be tall enough at full pressure to make contact with the upper and lower spring seats to make a difference in ride height. The only other thing that may be limiting the amount of rear suspension travel would be my stock Nissan adjustable shocks which I have no idea how far they can stretch before bottoming out... BrSurfer Do you have aftermarket/JGC/Calmini rear coils? Or are you running stock height? If you're still running the OEM adjustable shocks, my guess is that they don't have enough extension to allow your rear suspension to lift. Have you tried disconnecting them to see if the ride height increases? BTW, I think Mr. Jim runs (or did run) airbags in his Finder.
Well, I don't have one of those new-fangled color GPS units, but I do have an older Garmin GPSMap 76S. It's been a fantastic unit and I really like the ability to plug in an external antenna. Even with the internal antenna, it outperforms our office Etrex units by a large margin. I can even receive 2-3 satellites while sitting in my living room, on the middle floor of my house! Because it's waterproof and floats, I use it all the time on my jetski. Last week on vacation, it worked great for navigating the Intercoastal Waterway and the tidal creeks around Beaufort, SC. We would have had a hard time navigating with maps alone....those tidal creeks all start looking the same after awhile. Of course, I had preloaded the topos for the area, which also shows the navigational markers, marinas, and boat ramps, as well as the coastal island/marsh detail. If I have a complaint, it's because of the slow data transfer to and from the unit. The GPS manufacturers have taken a long time in moving away from the old, slow, serial interface. To load 20 megs of maps in my unit can take 35-45 minutes! I note that the new 76C(S) has a USB interface, which would be worth the extra money to me. http://gpsinformation.us/gps60c/g76Creview.html
Will this brush grill support a winch??
gacruiser replied to delavoie's topic in 90-95 WD21 Pathfinders
No. The strength of the factory brushguard is nowhere nearly strong enough for winch duty, even with reinforcement. Plus the fact yours appears bent. My first brushguard was bent in a minor accident. I replaced it with a TJM bullbar. No comparison WRT strength. -
I know where a '96 Black twin turbo has been sitting for the last 3 years. Has under 30K miles. The guy hasn't driven it since he bought his Chevy Trailblazer. Been trying to buy it, but he's out of his mind on price..... :furious:
Yeah Pickles, I've towed quite a bit with my '91 auto Pathy. Normally, at 70-75 mph, I'll get 18.5-19 mpg. With a medium U-haul (5'x10'?) enclosed trailer loaded with about 2500 lbs of furniture, it will get 13-15 mpg, depending on hills. I used to have a large Pop-up trailer, weighed about 1200 lbs. Would get 15-16.5 mpg on the highway. As an aside, I've tried dropping my highway speed to 60-65 mpg (no trailer), and have seen the mileage shoot up to 20.5-21.5 mpg on long trips. This is with stock 31-10.50 BFG AT KOs.
North of Atlanta, in Buford, GA. The older Pathys are getting few and far between around here.
Not yet!
