Steve_RI
Everything posted by Steve_RI
  1. What the heck is that rubber tube (about a 1/2 inch or so) that runs behind the center console. You can grab it if you remove the ashtray. The dam thing was whistling and driving me nuts. I didn't know what the heck it was until I took everything apart and squeezed that tube and it stopped. Sounds like a little fan in there?
  2. Okay, the needle stops just barely shy of E.
  3. I just spayed it down good with WD-40....it was too cold out to mess around. When it warms up I'll use some spray grease.
  4. Sprayed the linkage and it loosened right up.
  5. Thanks, I'll spray it tonight when I get home.
  6. i'm going to need 4WD this weekend, big snowstorm, so heading north. The shifter for 4 wheel drive was very stiff (auto hubs). It engaged fine, but I could only test it briefly...didn't want to take any turns on the pavement. Granted I do not use 4 wheel a lot, but it's never been that much effort to engage 4 wheel. Is there a linkage that I can spray or is this a lubrication issue at the hubs?
  7. Excellent, thanks. I'm good to go for now, I'll get rid of that last hanger and add this one back in the Spring.
  8. That lower control arm is a fun one, huh? I had to do it twice on my 89 because the first time it squeaked so bad I couldn't take it. I would use the split urethane bushings for the rear if and when I need to do this on the 92.
  9. Okay, new exhaust is in finally. The makeshift hanger on the muffler will do for now. I'm assuming that this is the missing hanger that I need to mount to the frame?
  10. I was able to hang the exhaust using the oem hangers on the tailpipe and muffler. I had to make a new bracket for the tailpipe as the one from the pic on post 6 was obviously not the stock mount. The stock mount on the muffler was still there. The shop had welded a hanger to it (like the one in post 6), so I cut that off, drilled a new hole and was good to go. The forward bracket on the muffler that bolts to the frame is a head scratcher. Right now I have a makeshift strap. Pics of these mounting points and stock brackets would still be very helpful, especially the one on the frame. I ran out of wire welding a flange to the cat, so I will finish that up tonight or tomorrow. I have an adapter for the other end that I'm going to just clamp and call it good.
  11. No email information on the invoice, sorry.
  12. I can check the invoice when I get home to see if there is an actual email contact. My order reference number on Ebay, if you can contact him, is 232495391619. You may need to create an account to get these things.
  13. A picture of the stock hangers would be very helpful. I had a custom exhaust shop put the Borla cat back on. Good work, everything welded nice, no clamps. For whatever reason it rusted very quickly and basically fell off the truck. I have the Walker 47752 cat back (Autoplicity - cheapest and fastest delivery I could find) and the Magna Flow 53004 universal cat (Amazon $46). Since the Custom exhaust place welded everything, I need to replace the cat...no biggie, it's shot anyway. I may do some welding on the cat (a flange or adapter on the muffler end and a welded butt joint on the other. I would like to go back to close to stock as possible with the hangers so I ordered the Stock ones Adamzan mentioned (Walker 35126). I'm trying to avoid welding to the muffler and tailpipe hence the pic would be great. Here's a pic of the tailpipe hanger that was welded to the tailpipe..I popped it off to paint it: If I could see how the stock exhaust is mounted to the frame I can get an idea of what else I need to mount to those stock hangers I ordered (Walker 35126). It looks like I just have to cut that hook piece off and use some type of strap. I could have the exhaust shop weld it up again, but I'm trying to save some cash.
  14. See Post 20. If he doesn't have them listed send him a message, he got right back to me when I had a question.
  15. It was the aluminized Borla cat back with the slightly bigger pipes. Rusted faster than hell. I remember when it was installed because the Pat's played the Falcons in the Superbowl the next day. I was hoping for a quick turnaround but it looks like I'm going to have to come up with something for the hangers.
  16. I had an aftermarket exhaust welded in 3 years ago and it's shot. Going back to stock pipes. Picked up a universal cat and a stainless steel muffler and tail pipe. Does anyone have any pics of the exhaust. I need to go back to the stock hangers. I don't want to Weld anything to the stainless.
  17. Brake cable came in and they are an exact match. Crawled under the truck and measured the cables, same length. This thread was all over the place, so to sum things up for someone perusing this thread: Rear DISC and Rear DRUM are different part numbers. 36530-42G16, 36531-42G16 are the OEM part numbers for the REAR DISC Pathfinders (see post 16,18). I think the 36530-42G15, 36531-42G15 are the Terrano part numbers. New cables are hard to come by these days and Rockauto, among others, only carry the cables for the rear DRUMS. Post 20 illustrates the differences, so make sure you specify the cables you are ordering for the Terrano if ordering from overseas vendor. Paid $89 delivered for the set.
  18. I was thinking of tweaking the float, but I just wanted the truck running. It's still a possibility, but I really want to fill it up and run it down close to empty to get some visual and measurable results.
  19. Well, this was a huge pain in the ass, especially in 25 degree temps, but I'm happy to report that the newer fuel sender works fine in the older Pathfinders. I bent the copper lines as close as I could to the old ones, but it was still a pain. I spliced in the new lines in right about at the spot where they make there straight run to the front after the rear wheel. They looked pretty good running up to the front of the truck from there. I'll report back after a trip when I can fill it up and see if it's off. Fyi, If you are under the truck in the rear poking around, the high pressure line is the bottom one.
  20. Source for parking brake cables for 4 wheel disc. I believe this has been posted before, but this seller on ebay has the cables listed for the Terrano, which is essentially a Pathfinder. He includes an illustration to pick the set you need. Item 2 is the cable set for the 4 wheel disc. https://www.ebay.com/str/LOKALIZOWANIE?_trksid=p2047675.l2563
  21. Here is the comparison between the two units. As you can see they are very similar, the old one being slightly longer with the float sitting lower. Given that these go in the same gas tank with the same fuel pump the difference must be at the instrument cluster. The old trucks have a horizontal gauge while the newer trucks are vertical. I think this should work fine and will probably be off an 1/8 of a tank or so.
  22. Well, since I'm waiting for parts I'm going to run the new lines and get everything ready. Am I correct in assuming the high pressure line runs to the fuel filter?
  23. I had that guage on my 89, haven't thought of that in years. I pulled a lot of parts off that truck, wish I saved the sending unit. I'm going to get the new one and find out. Could benefit someone down the line.....
