offroad95pathy
About offroad95pathy
  • Birthday 12/04/1954
    4 DR XE Pathfinder 3.0L 5SP MT, Engine: Taylor 8mm spark plug wires, Bosh Platinum 4+ plugs, Accel Super Coil 42K volts, Accel 300+ Ferro Spiral Coil Wire, Weapon R cold air intake, Doug Thorley chrome headers, AC Oil Filter relocation kit, Nismo Oil Cap, CS-144 200A Dual Rectifier Alternator with line suppressor, Flexalite Dual 12” Low profile fans (FAL-210), CoolFlex upper and lower radiator hoses, Evans NPG+ coolant, AMSOil 20W-50, Mobil 1 filters, Oil cooler, custom fab full 2.5” dual exhaust with Magnaflow stainless round mufflers and Magnaflow high flow cats, SPEC Stage 3+ FX400 6-puck disk & plate kit, Fidanza flywheel. Chassis / Suspension: 3” BL, 3”+ SL, All chassis and suspension bushings replaced with Energy Suspension polyurethane bushings, Heim joint TREs, MOOG Upper/Lower Ball Joints custom TRE adjusters, Modified Calmini CL kit, EBC dimpled & slotted rotors, PBR Ceramic/Kevlar Pads, AC Stainless Steel brake lines F/R, Motul RBF600 brake fluid, Rancho RS9000 series shocks (RS99112 Rear, RS99214 Front), New NAPA premium calipers, New rear Raybestos drums, Beck/Arnley hardware & AC Delco rear cylinders, new Nissan backing plates, Sway-A-way torsion bars, Calmini HD 3” rear coils, Calmini HD centerlink steering system, Calmini HD UCA’s (I redesigned/modified the bushing collars and the way they mount to the UCA spindle, will follow with a detailed description and photos in the near future) Pro Comp XTerrain 33x12.50-15 tires on AR Burst 15x8 chrome wheels, Rancho RS5000 steering stabilizer, Warn manual locking hubs, new AC CV axles. Interior: MOMO Carbon Fiber shift, trans case, and E-brake knobs, Roll/Pitch meter, OBX pedal cover kit (GT-5G Titanium), Carbon fiber dash kit, Rancho in-cab remote control, Beltronics Vector 995 Ultra radar detector. Exterior: Lund Windjammer rear top deck spoiler, Ventshade Bugflector II and side window Ventvisors, Chrome front/Rear bumpers, Nissan Euro crystal clear headlights and signals, clear side markers, PIAA Extreme White headlight bulbs, 2x PIAA 540 series extreme white driving lights, PIAA 60 XT super white driving lights for rear backup, chrome side mirrors, 2x Pilot PL-2700 Ion Fog lights, modified rollpan area, rear mounted tire carrier. Audio: Kenwood KDC-5028 CD/MP3 deck, Kenwood KGC-6042A Equalizer, Boss RIP796 4CH 1600W amp for front/rear speakers, Boss RIP596 1000W bridged amp for subs, 2x Infinity Reference 12” subs mount in Q-Logic QLH-1.2512DS enclosure w/sealed port, 2x Kole Audio 1.5 Farad caps 1 for each of the amps, Boss BX55 2/3 way active crossover, Infinity Kappa 692.7i 6x9 rear speakers, Infinity Kappa 682.7cf 5x7 front speakers, Infinity Reference 1011t silk tweeters front/rear, Phoenix Gold Platinum series interconnect cables RCA/RCA, Monster cable 14ga twisted pair speaker wire. LF/HF cutoffs for front/rear to subs is 250 Hz, tweeters HF cutoff is 2500 Hz. Future Modifications: LSD for the front diff, ARB Air locker for the rear diff, custom sliders, Yakima roof rack, build a new engine with a 3.3L lower end, VG30DE/DETT crank and rods, VG30DETT oil pump, VH45DE pistons, P&P the 3.0L heads, JWT S2 cams, JWT ECU, ARB front bumper, Mile Marker hydraulic winch, custom front bumper, MOMO steering wheel. Right now my truck is off the road, rebuilding the entire front end and rear suspension.
Contact Methods
  • Website URL
    http://
  • ICQ
  • Interests
    offroad racing, any extreme sports, motocross racing, ATV racing, motorcycle road racing, music, computers, off road trailing, Astronomy, Physics, Digital Photography
offroad95pathy's Achievements
NPORA Regular (2/5)
  1. With regards to the weight of a flywheel and torque, care should be taken in the use of terminology. The torque that an engine produces has nothing to do with the weight of the flywheel. In the most general terms and conditions, it is the amount of volume of air/fuel mixture moving thru the engine that gives you torque, how fast this volume moves gives you horsepower. It is torque, and torque only that is measured on a dyno, horsepower is derived from measuring the amount of torque over the working rpm range of the engine. A heavier flywheel slows the ability of the engine to excellerate, this is an inertia, unsprung weight issue. The extra weight provides additional momentum which conteracts the engine from slowing down ( giving the effect of so called more torque). Heavier flywheels also have a tendency to damage driveline components because of this same effect, when a spinning tire finally locks up, the energy has got to go somewhere, the weakest component brakes or you burn up a clutch etc.
  2. If your looking for a Fidanza flywheel for your pathy, you need to get part #143871, this F-wheel has a 250mm disc surface, the #143281 is a 225mm disc surface and only works with 240, 260 and 280 Z's are the main applications, there might be a few others.
  3. The backspacing measurement is the distance from the mounting surface of the wheel to the back surface (lip) of the wheel. Offset is the measurement from the mounting surface of the wheel to the centerline of the wheel. The smaller the backspacing, the more outboard the wheel/tire moves. Negative offset means the mounting surface is inboard of the center of the wheel (pushes the wheel/tire outboard). Positive offset is the opposite.
  4. I doubt that 3" of SL is is going to put you out of spec, or cause you to start having issues with you DS. But if your conscience needs to be soothed, once you get the lift finished, raise your truck so the rear axle hangs free without touching the ground and measure the angle you end up with (shop lift is the best way, where they can lift by the frame). You'll need one of those angle finders that can zero either horiz./vert., place it on top of the shaft and see what you get. You could actually calculate approxiamately what the angle change would be, but that's kind of a PIA.
  5. When you shim a leafed rear axle, that's what you're doing, pointing the pinion toward the trans output shaft, to help reduce the acute angle at the u-joints. Average OEM DS's will do 25-30 degrees either end, Cardan equiped shafts will do 40-42 degrees, these are always under full travel conditions. A well built shaft would be dynamically balanced, the orientation of the pinion to the output shaft will not induce vibration as long as the angles are not exceeded in full travel relative to the limits (angles and rpm) of the DS.
  6. Hey Skinny, I got a complete set I'll sell you for $20 + shipping, includes bushings and inner sleeves, Don't need them, I made new custom bushings and sleeves for mine. See Parts for Sale- 95 Pathy Parts.
  7. If you buy the BL kit from AC they supply you with all the hardware, bolts etc. that you'll need. The 2 rear bolts are High strength harden metric bolts with 1.00 (fine) pitch thread, the chances of finding a Metric HS bolt with fine pitch in the length and size you need locally is slim to none. Using threaded rod I would strongly recommend against that. Nissan uses the type of bolts they've chosen (OEM) for a reason, there is a huge amount of stress that those bolts are subject to, even more so with any increase in BL lift. The AC kit puts the right stuff in the kit, so no prob!
  8. Generally speaking, the greatest factor effecting torque is the velocity of the air/fuel mixture moving through the engine, higher velocity-more torque, the more volume of air/fuel mixture the more horsepower. There are headers designed specifically for either or a compromise of both. Small short tube headers are more for torque whereas large long tube headers are more for horsepower. So removing restrictions on the intake end is just as essential as dealing with the exhaust end of the system. Picking a good free-flow cat and the right type of muffler are also important.
  9. I know 95% sure that any 240SX from 1995-1998 will work, but you will in most all cases have to swap pulleys minimum and possibly shim/washers to get it to line up correctly, and there are either 80A or 90A versions. Hope this helps some.
  10. I believe the VG30 MAF is 50mm where as the VG33 is a 60mm MAF. I read a few places that the VG33 plenum is better than the VG30 due to a better air flow characteristics, it is supposed to provide some additional low-end torque???
  11. Looking forward to hear how that turns out. I was seriously considering the same, replacing the complete intake plenum, TB and MAF and everything in between. Didn't know you had to replace the VC on the TB side of the plenum though, still doesn't sound to bad. A few pics would be nice when you get it all back together.
  12. Why would you only swap out the MAF, you could also swap out the TB and upper plenum, opening up the entire airway so it could really get a good shot of air. I've heard of some mounting the 3.3 TB on the stock 3.0 plenum, but that requires some machining. I seen a few sources consistantly claim that the 3.3 plenum is more air flow efficient than the 3.0 plenum?
  13. Do a search on "lifts" or "suspension", and you'll find all kinds of info to read and research, there are some pretty comprehensive threads with lots of info on the topics.
