Casey.T
Casey.T last won the day on June 25 2012
Casey.T had the most liked content!
About Casey.T
  • Birthday 06/10/1968
    05 Fronty SE Crew Cab 91XE Time to have some fun
    XE
Contact Methods
  • Website URL
    http://
  • ICQ
    Spokane Washington
  • Interests
    FlyFishing for StealHead but will settle for trout due to where I live now, Hunting, Pathfinders
6,260 profile views
Casey.T's Achievements
NPORA Old-Timer (5/5)
  1. yo Thomas are you still active at the npora forum...call me I have a question...Neil 509-3120456
  2. Jared, May your family be blessed with all the goodness you have brought into our world...
  3. Check the connections at the starter, also the clam shell positive wire has been an on going issue. just a little corrosion in the connections at the clam shell can drive you insane for months.
  4. lmao @ Fueler. go figure. sorry about the white stuff.... I hear it's comin this way though :)
  5. I have the Calmini 3" kit, only thing i dont like is the Squeak... I would suggest if you go with Calmini, have the UCA drilled Tapped and add a grease zerk fitting... the RC UCA's come with the Zerk installed. I too liked the fact it was a Kit... UCA's, T-bars are a little stiff, rear springs and drop down bracket.... I might go as far as to suggest using the original T-bars...
  6. I remember having a H2O gasket fail on my 95(was not me that installed it) similar problems with the occasional leak. Found fluid dripping out the timing cover and behind it.... I know slick remembers the phone call that night and me with the wrong timing belt...
  7. Thats where my front bumper started :tonguefinger: few minor mods
  8. Please note your sig pic.... and I showed you that spot last time it was in the garage for the starter.....
  9. thats a good one.... suggest to them that the next time they do something like that, go with the Zebra instead....
  10. This is on the 95, but theres not alot of differences from the MAF to the Pop Charger.... Still have to transfer mine to the 91 and re-install the original air box in the 95.... for the mounting bracket, i used an existing hole in the wheel well under the air box... bend the bracket to fit and clearance the hood...
  11. If you dont change it, the extra stress can cause the waterpump bearing to fail... then your tearing the front end apart again anyways...
  12. not recomended.... major accident waiting to happen if you drive without it....
  13. If the tensioner is to tight, the belt will WHINE like a B!tch.... it could be as simple as a bad belt, it does happen once in a blue moon... Having had a belt come apart on me, id say it was too loose, the how too has a great way of setting the tension... hope that it did not eat the Valves...
  14. hehehehehehe :tonguefinger:
